Old 07-21-2009, 10:56 PM   #1
americanmusc1e
americanmusc1e's Avatar
383/700r4/3.08........and 10.5MPG!!!!!!
OK, the title says it all.
Vortec-headed 383 (actually a 388), Comp Cams XE268 cam, Holley 600 VS, and a Weiand Stealth intake......34 degrees total ignition timing
Built 700r4
stock 3.08 gears with an open diff
I'm getting 10.5mpg.
is this normal????? or do I still need some tuning????
1900rpm at 70mph--- is this too low???
with the old stock350/th350/3.08 I got 12mpg!!!!!!
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 07-21-2009, 10:58 PM   #2
knsmodels
I make Models
knsmodels's Avatar
Re: 383/700r4/3.08........and 10.5MPG!!!!!!
seems low to me....I get better than that with my stock K/10.....
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 07-21-2009, 10:59 PM   #3
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Wow Thats Horable....
1971 GMC SHORTY is offline   Reply With Quote
Old 07-21-2009, 11:02 PM   #4
smoky02
Location: Sunny, Florida, some might call it South Alabama
I have the same setup, well minus the 383, and I'm getting around 18-23. Highway of course, in town is around 14 or so. I would say that's about right
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 07-21-2009, 11:05 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
With all of that stuff put together, how sure are you that your odometer is accurate?
I have a stockish 350/700R/3.73. About 12 around town and 16-17 highway. My odometer is off by 9%, so I take that into account in my fuel mileage calculations.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-21-2009, 11:16 PM   #6
Hart_Rod
Hart_Rod's Avatar
Seems like you would be lugging the motor with the OD and 3.08 gears. I bet 3.73s would move you up a couple of MPGs....
Hart_Rod is offline   Reply With Quote
Old 07-21-2009, 11:17 PM   #7
BarryB
BarryB's Avatar
Yeah with the cam you have at lower RPMs your motor is struggling you need to get some RPMs in the motor to benefit from your cam, either swap out the cam to something more stcok, or put a deeper gear ratio in. 3:42 probably do you pretty good. BUT a 383 where it has a longer stroke, it does tend to suck in more fuel.
I basically had the same set up in a Nova, once I change out the rear gears. I put in a 3:23 ratio. It did better.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-22-2009, 12:01 AM   #8
69GMCLonghorn
69GMCLonghorn's Avatar
As stated, you should be getting higher than that.
As for the "lugging" thing... YOU ARE NOT LUGGING THAT ENGINE! If it's working too hard, you'll feel it in your right foot. If you want to prove me wrong/right, drive it in 3rd for an entire tank of gas. If it gets better than what you're getting now, I'll eat my shoe...
69GMCLonghorn is offline   Reply With Quote
Old 07-22-2009, 12:13 AM   #9
Jim_PA
I bet it's running way rich, and are you using vacuum advance? At 1900 RPM's, I doubt you have much mechanical advance. I think you would see some great increases in MPG if you were to get the carb cruising on the idle circuit, and throw some vacuum advance ontop of that. Is your power valve working, and is it properly sized?
As it is now, you're probably on the mains right off idle, and it's just wasting fuel.
Jim_PA is offline   Reply With Quote
Old 07-22-2009, 12:22 AM   #10
bamabaxter
bamabaxter's Avatar
i have a 383/700r4/3.73 gears. I also want to know if your speedo is correct. That could be the main problem. At that rpm you definitely need some vacuum advance. what do your plugs look like?
'72 Chevy C10
383, 700r4, 3.73's
A little rust never hurt anyone. I consider it weight reduction.
bamabaxter is offline   Reply With Quote
Old 07-22-2009, 05:18 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
your RPMs are too low, you are under the torque curve. While you aren't ligginh it, you are under the curve and it takes too much throttle to try and maintain the speed.
9 times out of 10, a 3.07 and overdrive are not a good combination.
Old 07-24-2009, 08:08 AM   #12
Jim_PA
With his combo, I doubt torque at 1900 RPM's is a problem.
Old 07-22-2009, 05:49 AM   #13
3.42s are my limit for o/d.I consider 3.08s to equal o/d running 1:1.I also think you actually need a bigger carb for that motor.Sounds funny,but the circuits in a carb increase flow progressively and a bigger carb will be pulling less fuel at 70 mph because it`s at a lower point of the carb`s range.
Old 07-22-2009, 09:00 AM   #14
bamabaxter
bamabaxter's Avatar
highly recommend some 3.73's. At 65 mph I am at about 22-2300 rpm. I don't have my converter lockup wired yet but I am told that it will drop me another 200 rpm at cruise speed. I remember someone on this forum talking about running 3.08 and 700r4 with a 454 motor. I think his was a low rpm motor with an rv cam or something similar. He got really good gas mileage, like 18 or something but like Longhorn said, you are probably opening the vacuum secondaries. I found the best thing that helps you "see" what your carb is doing is a vacuum gauge. I just got one that actually mounts on the dash. Definitely taught me a lot in the past few days.
'72 Chevy C10
383, 700r4, 3.73's
Old 07-22-2009, 09:01 AM   #15
69GMCLonghorn
I disagree with the folks saying he's overdriven. I DO agree that there is probably a timing advance problem. Trying to get the carb to be on the idle jets when cruising will not happen as the carb is OFF the idle jets by the time you get just over 1000 - 1200 RPM. Maybe he could put a Gear Vendors behind the 700R and get those R's down a little more???
Seriously, just to prove me wrong or everybody else wrong, drive it in 3rd for an entire tank of gas and see what your mileage does. If it's worse, then gearing isn't your problem and tuning IS.
Old 07-22-2009, 09:16 AM   #16
americanmusc1e
OK, so everyone pretty much agrees with the tuning ideas I had:
swap the holley 600 for a modified (and properly calibrated) Q-jet (750cfm)
tune the ignition timing
3.73 gears-- that is why I got the OD in the first place, cuz 3.73's are on my list of modifications
check the odometer for accuracy (pretty sure the speedo is correct, we checked it against my brother's truck)
I WILL try to drive it in 3rd with the converter locked up to see what my mileage does
-- Josh
Old 07-22-2009, 09:21 AM   #17
DANTIP
DANTIP's Avatar
I had a ZZ3 350 with a 700R4 and 3.07 gears and I was able to get 20 mpg on the highway. The torque curve is excellent on the ZZ3 even down to 1800 rpm. Your 383 set-up may not be as friendly at low engine speed.
DANTIP is offline   Reply With Quote
Old 07-22-2009, 09:22 AM   #18
americanmusc1e
OK somebody help with my ignition timing!!!!
stock HEI
without (ported) vacuum advance hooked up: 12 initial, and 20 total mechanical
with (ported) vacuum advace hooked up: 34 degrees total
all the advance is in before 3000 rpm
somewhere I read that you are supposed to hook the vacuum advance to full manifold vacuum????
-- Josh
Old 07-24-2009, 08:06 AM   #19
Jim_PA
The idle circuit is not a function of RPM's. It has everything to do with the amount your throttle blades are open. Modify the idle circuit properly which will allow you to close the throttle blades more at idle. (I'm still betting he's almost pulling from the main jets at idle...) Do a little research on idle circuits before posting something that sounds way off base.
Use full manifold vacuum -
Old 07-22-2009, 09:32 AM   #20
bamabaxter
bamabaxter's Avatar
It is a never ending battle about what vacuum port to use. Depends on what you want. First thing you need to find out is how much advance your vacuum canister adds and at how many inches of vacuum it comes in. You may need an adjustable canister. You said you are running stock hei, but with and aftermarket motor setup up it changes the vacuum levels in the motor. This is when a vacuum gauge and pump come in really handy.
'72 Chevy C10
383, 700r4, 3.73's
Old 07-22-2009, 09:33 AM   #21
Ackattack
Ackattack's Avatar
what size of tires are you running?
My gas mileage improved when I went from 3.08 to 3.73s (14mpg to 18mpg) with a TPI 350 and 700R4.
Ackattack is offline   Reply With Quote
Old 07-22-2009, 09:38 AM   #22
americanmusc1e
My gas mileage improved when i went from 3.08 to 3.73s (14mpg to 18mpg) with a tpi 350 and 700r4.
31"
-- Josh
Old 07-22-2009, 09:41 AM   #23
bamabaxter
bamabaxter's Avatar
What did the hei come out of. Give me the year and specs and I can look up the vacuum specs on the canister.
'72 Chevy C10
383, 700r4, 3.73's
Old 07-22-2009, 09:45 AM   #24
americanmusc1e
sorry, I have no idea, I bought it used and I don't know what it came out of
-- Josh
Old 07-22-2009, 09:44 AM   #25
69GMCLonghorn
You need to hook the vacuum advance up to a ported outlet on the carb so you don't get advance when you don't want it.
Also, I don't know anything about cams and timing, etc, but i have a built 350 and the guy that tuned mine has a total of about 44° of advance dialed into it. Once he did that, my bottom end came alive (Did I really just type that?!?!). In fact the low end is so much better now that my tranny whines if I pour it on around 1200 RPM (it's a stick).
For sh**s and giggles, try giving yourself more base timing and keep the vacuum advance disconnected. That is how mine is set up and it works great. Just no idea how it will work on yours. FYI, my base timing is something like 25 - 30°!!! I dont' know how it works like that without pinging, but it does!
