Wiseass secured himself a BAN
Starter Question
I am switching from the cast iron bell housing to the aluminum type bell housing. What is the part number for the starter that goes with aluminum bell housings?
Thanks Ben |
huh ???
Should be the same starter. It bolts to the engine not the bell.
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Fabricate till you "puke"
The trucks ran a 168 tooth flywheel/flex plate(14" dia). The starter that fits the auto trans apps, or alum bell stick , will have a staggered boltpattern. If you by chance you have the smaller flywheel(153 t, 12 3/4"dia) the starter has a straight across pattern,& both starters bolt to the block as posted. If the truck starter that you have is good, you can change the end housing & bolt it to your block......arent Chevs great! i cant help on part #, but good luck......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thanks for the info. I am going with a T56 6 speed once I get all the detailed problems worked out. I just wonder what else I am going to have to change to make this work.
Ben |
