Fan shroud
I have 72 blazer basket case has 396 when I got it motor was in but hitting fire wall so got some info off the board here moved cross members up 2 inchs everything is going together. But now what are the fan shroud options is there a shroud that will work or do get rid of stock fan go to electric fans?
![]() Join Date: May 2007
Re: Fan shroud
Get a 2wd bb shroud. Sometimes used ones come up or you can buy a new one.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Re: Fan shroud
Okay thanks for the info. 2wd that much shorter?
Re: Fan shroud
If you mean front to back (from radiator to firewall) yes, WAY shorter.
GMCDAC
Re: Fan shroud
Scott (Turp Mcspray) is right on on that deal, 4x4 shroud is 9" deep and a 2wd shroud is about 5 1/4" deep.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() Last edited by 70gmcjimmy; 07-25-2009 at 06:41 PM. |
#6 | |
![]() Quote:
On my truck I moved the engine forward 2" from the small block location and with a factory water pump,pulley,and clutch fan set up (borrowed from my buddys 2wd big block truck for mock up), the fan set perfectly in my shroud.
#7 | |
GMCDAC
Re: Fan shroud
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
