07-26-2009, 10:22 PM | #1 |
the pollock
shock extension(hyperextension?)
hey gentlemen, i will start by saying i am not the one who put these shocks on..
im just the one paying the price (reffer to my build thread for all "repairs" that i have repaired...) so my fronts WERE dual shock, remobed brackets and brought it down to single shocks.. my spine was hurting perod.... everthing was like driving on brick suspension and bare rims... so now.. the ride was much smoother.. but my rear likes to "dance" alot.. too much.. so here i was installing new exhaust hangers and i have noticed my rear shocks seem to be fully extended at rest in the driveway. now this MIGHT be my fault due to me changing to 14bolts in the rear from a corp 10, but skyjacker diddnt list a different partnumber between the two k series trucks (unless im blind) so.. i am assuming i have the incorrect shock installed on the rear so the solution is? 1/ bring bolt holes down on the frame for my shock and "raise" the shock bracket on the axle... or buy longer shocks.. now.. my wife will freak if i dont describe this correctly to her.. and just go buy new parts off a whim what do you think i should do? moving both peices can gain me at least 4 inches (derived/assumed from basic measurements) i can weld (not frizzleFry style but like 4yr old fingerpaints) good and strong let me know what your input is.. what one would you do? and i do respect your opinions and professional input. thanks!
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
07-27-2009, 11:17 AM | #2 |
Grease Monkey
Re: shock extension(hyperextension?)
I'd say new shocks. ProComp $32ea
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
07-27-2009, 12:57 PM | #3 |
the pollock
sweeeet diddnt realize they were that cheap..
07-27-2009, 02:24 PM | #4 |
The only way to get the right shocks for your specific application is to unbolt your shock(one end will do)and drive thru a ditch or something that will fully extend and compress your suspension. With your axle fully compressed or drooped measure the distance between the upper and lower shock mounts, right this number down, change your position in the ditch so the axles are now compressed or drooped the other way, remeasure the distance. If you look in a shock catolog it will list all shock dimensions, fully compressed and extended. Find the dimensions that work on your truck and order. No more too long or too short shocks again! I would not trust the lengths they send you in your lift kit to be correct in any situation other than plain old street use.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-27-2009, 03:16 PM | #5 |
Everything is work in progress
You could disconnect one shock, use your handyman jack and raise the truck till the wheel is just off the ground via the frame or bumper (on the side you removed the shock from) measure that extended length from shock mount to shock mount. This is the maximum extended length (lets say 34"). Lower and remove the jack. Next measure from where the bump stop would touch the frame to the top of the bump stop add 1" to that number (for bumper compression) (lets say that number is 7"). Then measure from the top shock mount to the lower shock mount (lets say that number is 25") and subtract your bump stop to frame +1" number. The difference between two numbers ( 25"-7"=18") is the compressed shock length.
Look for a shock that will travel within those lengths (34" to 18"). If you can't find a shock that fits in between those two lengths either A: raise your bump stop until your compressed length gets into range or B: install a limiting strap that reduces your maximum extended length to within range or C: ask yourself what kind of off-roading your going to do (will your ever have one wheel off the ground?) and select a length that is a happy medium for your needs.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 07-27-2009 at 03:23 PM. |
07-27-2009, 04:51 PM | #6 |
the pollock
thank you!
i turned down buying new shocs today because skyjacer had lengths labeled off the lift itself.. so i diddnt bother... thans for the input guys this will be a "new future" project for me..
