07-27-2009, 10:53 AM | #1 |
454 MAKES IT ROAR
Rear end noise
So i've just put my D/S back on the truck with my new combo U/J where it broke out of the pinion yoke, started her up and took it very gingerly out the drive and onto the road, I could not get it much over 15mph as a strange vibration and or whiring sound would start to come from under the truck. Had a look underneath and nothing had changed except for a small oil leak from behind the pinion yoke so I realise that means I need a new seal. But can anyone tell me what other unseen damage could have been done to the axle when the D/S broke out of the P/Y a few weeks back??
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
07-27-2009, 10:59 AM | #2 |
Restoration Virgin!
Re: Rear end noise
Well Crap Nigel!!!....Fix one thing something else goes!!!....
Not sure of the problem, but have you changed the rear end oil and gasket in awhile??.....if you do, run your fingers through the oil as it drains for any metal filings??.....Maybe something happend to the ring/ pinion when the DS broke?? (this is purely a guess!!!)
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-27-2009, 11:03 AM | #3 |
Under Construction
Re: Rear end noise
could the drive shaft have thrown the weight when the u joint broke? did you install the ujoint or have a shop do it. you may want to have the balance checked. is this a 2-piece d/s with a carrier bearing?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-27-2009, 11:17 AM | #4 |
Re: Rear end noise
Did the driveshaft get any dings in it when the cross broke? I've also seen them damaged when someone went wild clamping them in a vise to work on them.
07-27-2009, 11:35 AM | #5 | |||
454 MAKES IT ROAR
Re: Rear end noise
Here is a vid i've just taken....the exhaust noise drowns out the whiring sound coming from the rear end, but WTF is that terrible sound when I take my foot of the gas.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 07-27-2009 at 01:37 PM. Reason: spelling |
07-27-2009, 12:46 PM | #6 |
member #16
Re: Rear end noise
Looked like the yoke was moving back and forth in the second vid. Did you use a new crush sleeve? See if you can move it front to rear.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 07-27-2009 at 12:48 PM. |
07-27-2009, 12:56 PM | #7 |
454 MAKES IT ROAR
Re: Rear end noise
When I was fitting the new pinion yoke tightening the centre nut the yoke would throw out forward, I assumed it did that when it engaged or something...sorry I don't know what a crush sleeve is John.
07-27-2009, 02:09 PM | #8 |
Re: Rear end noise
i agree. i think something is wrong inside the rearend. that input shaft should not move that much. one thing i notice in the "repaired" pic, is the cap of the new u-joint doesnt look like it is contacting the "tang" of the new yoke. it could be that you have a mismatched u-joint and yoke.
i had that problem before, where my ujoint was 1/8" shorter than the distance between the two tangs of the yoke. the drive shaft would slide back and forth everytime it rotated. cause a wierd vibration and crazy sound. |
07-27-2009, 02:10 PM | #9 |
member #16
Re: Rear end noise
OK I am assuming that is a truck 12 bolt diff. Here is a link on how to set up a 12 bolt, which explains the crush sleeve.
http://www.hotrod.com/techarticles/d...ide/index.html In your first pic it looks like there are a couple of threads sticking out of the nut. Second pic looks more like it is flush with the nut. You should not have any noticible end play in the pinion shaft. There must be some reason why the yoke tightened up before the end play was gone, burred shaft etc.I would pull the yoke back off and find the prob. before driving it. Alot of guys reuse the sleeve in a pinch by not overtightening and overloading the bearings. If the yoke is free on the shaft you will be able to tell when you come up against the sleeve to your old adjustment. Kinda longwinded hope it helps.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
07-27-2009, 03:40 PM | #10 |
Re: Rear end noise
Also, be sure not to overtighten the straps holding the u-joint onto the new yoke. Most people way overtighten which can cause binding and premature failure. A suprisingly low amount of torque is specified, something like 10 ft/lbs I believe or even less. Look it up or maybe someone here knows the exact figure.
07-27-2009, 10:27 PM | #11 |
Re: Rear end noise
You definitely have some extra slack at the pinion. Someone stated earlier that it looked like the nut was not as tight as previous and I agree with them. You need to locate the torque spec for the pinion nut and do that again. The nut is swedged and should not need loctite on it but if you use some use blue not red. I would also pull the rear cover and with a depth gauge check the pinion as well as the gear pattern after you retorque the pinion nut. You can do this with some white lithium grease to check the pattern. The pinion gears should ride in the middle of the ring gear and since yours is obviously an older (i.e) stock rear end there should be an existing pattern worn into the gears to go by. Definitely pull rear cover , retorque pinion nut to specs and check pinion depth with guage and your movement and noise should be gone. Good luck as this can be intimidating especially if it is your first time but it can be done.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
07-28-2009, 05:01 AM | #12 |
454 MAKES IT ROAR
Re: Rear end noise
Thanks 71 super going to do that today. I must admit I can't imagine it's just down to how tight the nut is.....remember all this happened because my d/s broke out of the pinion while I was driving and it was flailing around under there until it fell off, so i'm guessing it must have done some other internal damage.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 07-28-2009 at 05:02 AM. Reason: spelling |
07-28-2009, 06:29 AM | #13 |
454 MAKES IT ROAR
Re: Rear end noise
Ist pic was taken when I changed the gasket and oil about a year ago...
This pic I have just taken, it's clear something major has happened.... Hopefully someone will know what might be broke....or should I just start dismantling?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 07-28-2009 at 06:30 AM. |
07-28-2009, 10:03 AM | #14 |
Re: Rear end noise
Give your pinion a pull forward and rotate it again holding pressure on the pinion to the front. If the noise goes away it is in the pinion and could be solved by the correct torque on the pinion nut. Give your axle shafts a tug as well just to be sure the shafts are not broken. You can do this by pulling on the wheels to see if there is give; there should be very little to none. From the grind marks on the carrier something is loose and flopping obviously and there are not many options. I think it is the pinion being too loose but check the axles and the carrier saddles for cracks just in case.
07-28-2009, 06:59 PM | #15 |
454 MAKES IT ROAR
Re: Rear end noise
I have since discovered that the grind marks on the carrier were made by the teeth on the pinion drive shaft because it seems to be able to move in and out of the differential. I am able to pull the shaft in and out which shows way too much play........ what do i need to do to correct this play? Is it the shims or can this be corrected by further tightening of the nut on the pinion yoke? You were right 71super, when i pull forward on the pinion shaft the noise does go away but it still dosnt feel that smooth when I turn the wheels.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 07-28-2009 at 07:09 PM. |
07-28-2009, 09:27 PM | #16 |
Re: Rear end noise
Tighten pinion nut until fore / aft movement goes away and try it. If your not using an impact wrench you can tell when the crush sleeve slack is taken up pretty easily (it'll get really hard to turn the nut). Worst case you trash the pinon bearings and you need to overhaul, versus a grenaded rear end from pinon gear to carrier collisions.
07-28-2009, 09:39 PM | #17 |
454 MAKES IT ROAR
Re: Rear end noise
Thanks Phaedrus, i'll try that cause it's got to the point were I can do no more without special tools and a lot more knowledge.
07-28-2009, 09:42 PM | #18 |
member #16
Re: Rear end noise
You still need the yoke to slide fairly easy on the splines or you will never know when you are adjusted right. Good luck.
07-28-2009, 09:46 PM | #19 |
454 MAKES IT ROAR
Re: Rear end noise
Thanks John, and for all the advice that's been given to me by everyone......
07-29-2009, 10:10 AM | #20 |
Re: Rear end noise
It is possible that you have already trashed the pinion bearings or at the very least created a burr on the pinion gears. Get a machinist file and clean the edges of the pinion gears. To do this 1st remove the cross shaft in the rear carrier. It is held i place by a 5/16" pin/bolt. Slide the axle shaftS inward after you remove the wheels one at a time, there is a horseshoe type clip that holds the axles in place. Remove the clip with a strong magnet- sometimes when axles are slid in the fall out but not typically and the magnet is nearly fail safe. Slide the axles out into the housing tubes - no need to complely remove. Use 5/8 socket to then remove the carrier saddle bolts and note side and any shims that they might have in them- photograph! Repeat for the other side. Be careful here as the carrier will actually fall out. before it comes out replace the pin/crosshaft that holds the spider gears in place. This will save you some headaches later if spider gears come out with the posi. Now you can clean your pinion gear teeth or go ahead and pull it out to check bearings. The shims for the pinon are located under the lower pinion bearing and can't be removed without a press so if replacing bearings to a machine shop you must go. You should be ble to get numbers off the bearings to order replacements as well as the number for the front seal. When you get new ones have the machine shop press them on using the shims that you already have for the pinion (you will be replacing bearings not the pinion so things should not change. Install a new seal and a crush sleeve. This are available as kits from placs like richmond gear, and randy's ring and pinion. Summit and jegs also sell rebuild kits for $60 to $100 bucks. You will need a pinion depth checker to reinstall as the crush sleeve is a bitc* to crush in a vehicle laying on the ground so you might want a pro to do this especially if you don't have the tools. Here with the parts available the job is about a 2.5 hour job there with the wait and parts availabe (assumption) you will be down a week. Try tightening the pinion nut first. Fyi the torque settings for saddle caps is 55#, back lash (preferred) is .005 to .008 acceptable is .003 to .010. Pinion preload is new 20-25 #, used 5-10 #. Hope this helps and it could always be worse, axle shaft could have broken and/ or ring gear bolts could have sheared and removed themselves automatically through the housing ask me how I know Good luck with this, you can do it.
09-10-2009, 06:13 PM | #21 |
member #16
Re: Rear end noise
Is it fixed yet? Any good news?
09-10-2009, 07:37 PM | #22 |
454 MAKES IT ROAR
Re: Rear end noise
Well now...how should i put this? it is and it isn't. I took the advice I was given here and tightened the nut on the pinion yoke further which squeezed the crush sleeve even more on the pinion bearing and this helped remove that excessive in and out slack that I had on the pinion. Doing that left a lot more thread count on the end than had been there before, but I thought what the heck, hooked it all up and took it out for a run and it worked. So It has been successful up to a point, because im left with an obvious and annoying humming sound that comes in at 20mph and then starts to fade away at about 45mph so the bearing/bearings must be shot. I will buy the rebuild kit for it and follow 71 super's how to and get it done right, but for now it will have to do...no long journeys just local trips, it should hold out. I hope.
Thanks for enquiring John.
09-10-2009, 07:57 PM | #23 | ||
Re: Rear end noise
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
09-11-2009, 03:25 AM | #24 |
454 MAKES IT ROAR
Re: Rear end noise
Don't beat about the bush LONGHAIR, I can take it, give it to me straight
I was hopeing that the gears were not affected, I curse the day my d/s cut loose.
