Old 07-27-2009, 10:56 AM   #1
sams60gmc
sams60gmc's Avatar
Filling the seam down the bed.
So I was at the local back to the '50s pre car show friday night and saw a pretty trick '64 swb. And I noticed it has the seam in the back of the bed filled just like mine, but then I noticed he has the long seam that runs all the way down the bed filled too. I want to do it with mine because it looked really smooth and tied in with the seam on the end. Just curious what he may have used or what to use. Bondo? Lead? Any help is apreciated guys.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 07-27-2009, 11:01 AM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Filling the seam down the bed.
I'm welding mine. One side is done still have the other side to do. I wouldn't use filler. Lead may be a good option, but never messed with it.
Alan's Classic is offline   Reply With Quote
Old 07-27-2009, 11:50 AM   #3
sams60gmc
sams60gmc's Avatar
Awesome thanks for the reply. Do you have any pictures?
Old 07-27-2009, 12:18 PM   #4
Alan's Classic
Somewhere in my build, I'm at work right now.
Old 07-27-2009, 12:13 PM   #5
70 Suburban
Rods
Welding mine also. I have started but thats about as far as i have gotten
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 07-27-2009, 12:47 PM   #6
62 short step
62 short step's Avatar
I used body filler on mine. Seems to be ok. After 2 years its still looks good. I guess welding would be better.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 07-27-2009, 01:09 PM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
I kinda like the seam. If your bed is apart you might be able to lay the bedside flat and melt lead or even soder and let it flow level. I dont know if it will do it or not so finding a practice piece is always nice.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-27-2009, 04:11 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
I filled the seams on my front fenders using JB Weld epoxy. They were new aftermarket GM fenders of terrible quality and parts of the seam had 1/8" gaps. I thoroughly sandblasted the gap and then filled with regular slow dry JB Weld. They've been on the truck for 10 years now and the seam remains invisible as if it had been welded, and without warpage.
Old 07-27-2009, 05:24 PM   #9
shortbed70
shortbed70's Avatar
If you arent that good at welding and save yourself some trouble. You could get by with spot welding every 4 inches and then use a good panel adhesive designed for gluing body panels togather. I personally would weld it but TAKE your time. Trust me I welded the hood gap and its alot more work than you think.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-28-2009, 11:16 AM   #10
sams60gmc
sams60gmc's Avatar
Thanks for the help guys. I'm not to sure what I'm going to do yet tho. I just have a little 110 welder and doing that seam wouldn't be very easy with it, but next time I have access to a big welder I probably will do it with that and then a little filler over it to smooth it out.
