Old 07-27-2009, 01:04 PM   #1
billt
Power Steering Gear Spacer
I have a 67 non power steering frame. How thick does the spacer between the frame and the gearbox have to be? I'm trying to make my own. Im installing a complete power steering unit out of a 84 chevy. Thanks for any help
billt is offline   Reply With Quote
Old 07-27-2009, 02:17 PM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: Power Steering Gear Spacer
You dont have to have one at all. I have a 72 box on my 67 and dont have one
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 07-27-2009, 02:42 PM   #3
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
apparently you'll need to either heat the area and smash it in with a BFH, for the recess needed for the stock steering box, or use a spacer.
I think it's Captainfab that makes a really nice spacer.
jbristo- are you sure your frame is actually a 67? did ya smack it with a hammer or something?
afaik, the 'flat' 67 frame won't take a ps box un modified. This was in a recent thread...
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 07-27-2009, 03:08 PM   #4
jbristo67
jbristo67's Avatar
I have seen two unmodified that both fit. Two different trucks that is. I will take a picture if you want to see it.
2011 Nissan Armada
Old 07-27-2009, 03:42 PM   #5
john
member #16
john's Avatar
Please do. sounds interesting.
john is offline   Reply With Quote
Old 07-27-2009, 05:24 PM   #6
Mordachai
Mordachai's Avatar
I guess I'll bite my tongue next time a ps thread pops up,
I was under the impression that all 67yr frames were flat, but I can see later in the year it being included. I'll take your word for it!
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
Old 07-27-2009, 02:56 PM   #7
jorgensensc
jorgensensc's Avatar
Check the frame. Some '67 trucks actually had the notch and power steering. I looked at one in the junkyard not too long ago. I was very confused by it, but then after more research we figured out it was from the factory, but a late year production.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-27-2009, 03:06 PM   #8
jbristo67
jbristo67's Avatar
Shawn
Mine had no notch but fit fine
2011 Nissan Armada
Old 07-27-2009, 03:51 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
either way, a spacer is a bad idea. This was covered in detail about a week ago
Old 07-27-2009, 05:26 PM   #10
70C10Toejam
Hellasick
70C10Toejam's Avatar
depending on your PS pump setup...the '67 mounting location or the '84 mounting location, mainly regarding getting stock lines to fit, you may need to convert that PS box to flair fitting.
http://67-72chevytrucks.com/vboard/s...d.php?t=242458
Since the '85 lines would not reach the factory '70 pump location that uses the motor mount. If the pump was in the '85 location, the '85 lines might have worked.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 07-27-2009, 08:19 PM   #11
Longhorn Man
here's the link;
http://67-72chevytrucks.com/vboard/s...d.php?t=352231
I've seen 68's without the dimple, and I've seen 67's WITh the dimple. So always look, never assume.
