![]() Join Date: May 2009
Door panel texture
Based on what I've read it sounds like dying your original door panels is a better option than new, based on fit? The panels on my 77 are in good shape except on the top where the texture is worn smooth (arm resting on the edge) over the years.
Does anybody know how to replicate the texture to match the rest of the door before painting? I've tried to search with no luck...I"m a rookie so I may have been doing something wrong. |
Old Heap Driver
Re: Door panel texture
I have no idea if this would work but here's something I did with a fiberglass interior piece. I built an extension for a center console in my S-10 out of fiberglass and needed some "texture" before I sprayed it with SEM coat. I grabbed a spray can of bedliner material and layed down a couple coats. Once it was good and dry I hit it with SEM coat and now the piece has a grain look like vinyl. People have asked me how i wrapped the vinyl and kept it smooth.
Bryan
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Thanks Bryan, didn't even think of applying texture, I was going a different direction. I'll pick up an old door panel and do a little experimenting.
I used the spray called COLORBOND on my door panels and arm rests. I figured the arm rest being vinyl would feel rough instead of normal and they turned out great. and then I tried the door panels and they still feel the same as before.
I've heard of using a donor piece of vinyl and laying that on the dye when it was tacky then pulling it off.
I've never tried it myself though.
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
I'll give it a try when I pick up my "donor" panel.
Oh,you can't buy that new
![]() Join Date: Apr 2000
I used rocker chip guard before the spray bedliner was available in cans.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
