Old 07-27-2009, 07:53 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Fat mat who has it....
Who has this installed on there ride I know I should have asked before I bought it but....... I know I have heard people on here rave about please chim in guys and let me know the secrets of the install if there are any...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-27-2009, 08:13 PM   #2
vectorit
What?
vectorit's Avatar
Re: Fat mat who has it....
I just put in Dynamat on the floor of my burb, they are pretty close in comparison I think.
Trick is to do it on a hot sunny day, it will make it more flexible to form.
I plan on installing more of the stuff, but it is so expensive I can only afford to do a section at a time.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-27-2009, 08:21 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
110 sq feet of fat mat cot me 130 shipped.... And Its 102 here today sooooo it should be pretty flexable..
MEMBER #6377
Project "7DEUCE"
Old 07-27-2009, 11:30 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
t.t.t.
MEMBER #6377
Project "7DEUCE"
Old 07-27-2009, 11:47 PM   #5
caja_larga
I have used it in a couple of installs. It works great on the floors but on a vertical suface if does stick so great. I could be because it was not cleaned good enough i did clean the panel. I would buy it again.
caja_larga is offline   Reply With Quote
Old 07-28-2009, 12:19 PM   #6
Hawker7
I used it on my cab floor and it worked great. Probably would have even gone on even easier if I didn't do it when the garage was 50 degrees, but it went on fine.
Hawker7 is offline   Reply With Quote
Old 07-28-2009, 12:56 PM   #7
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I used it on my square body as well, worked fine and went on really easy.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 07-28-2009, 01:16 PM   #8
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
I put Fat mat in my 94 swb and it is not that hard at all. The key is to spend your time getting the surface as clean as possible. It killed alot of road noise.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 01-29-2014, 01:00 PM   #9
Longhorn 70
Longhorn 70's Avatar
Can FatMat or DynaMat be used under the hood?? Would it help reduce noise?
Sorry for resurrecting an old post.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-29-2014, 02:01 PM   #10
Hart_Rod
Hart_Rod's Avatar
I think they both sell stuff specifically for the engine compartment.
Hart_Rod is offline   Reply With Quote
Old 01-29-2014, 06:04 PM   #11
cleszkie
cleszkie's Avatar
I used it on the floor and sides of my Blazer before installing carpet and side panels. Very easy to install and really reduced road/exhaust noise. I don't think it would work well in the engine compartment. When it gets warm/hot the tar backing gets soft and it may peel off the underside of your hood under its own weight. There are other products for the engine compartment.
cleszkie is offline   Reply With Quote
Old 01-29-2014, 06:13 PM   #12
scotts72heavyhalf
scotts72heavyhalf's Avatar
My boys did the entire cab and doors with fat mat, easy to use, great product and price!
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 01-29-2014, 09:35 PM   #13
truckster
truckster's Avatar
It looks like your Blazer is occasionally exposed to the elements. Is there any concern with water getting into or under it?
truckster is offline   Reply With Quote
Old 01-29-2014, 06:25 PM   #14
BugzC10
BugzC10's Avatar
I put in the interior and under the hood. However, I've only driven it a couple short trips, but it seems to be quieter. I'm happy with it.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 01-29-2014, 08:52 PM   #15
ho70
ho70's Avatar
I used it on my floors and doors of my Challenger. Someone on the mopar board told me that he installed it on his roof and in the heat it came unglued and fell onto his headliner. If it isn't warm where you are, then use a small heater in the cab to warm the mat and a hairdryer when rolling it on the floorboards
ho70 is offline   Reply With Quote
Old 01-29-2014, 09:50 PM   #16
BugzC10
BugzC10's Avatar
Once I start driving her this summer I'll have to see if it starts falling off the underside of the hood.
