07-27-2009, 08:34 PM | #1 |
trying to keep it on the road
I have an 84 swb 4x4 with 6" lift it has a lifted steering arm but not the pitman arm. I cant hardly keep it on the road sometimes it pulls side to side. it was toes out but i pulled that in and it helped but didnt fix it. i have 33x15.5x15 tires could that be the reason or do i need to change something? i was told to drop the sway bar and take the shims out from under the perches. any ideas?
'68 K-10 IN PROGRESS OF A FIRST TIME RESTO. ANY ADVICE IS NEEDED. I'M IN NEED OF SOME PARTS TRUCKS NEAR MICH. THANKS |
07-27-2009, 09:28 PM | #2 |
Bloodied Knuckles
Re: trying to keep it on the road
6" lift will either require a steering arm (plus the "block"), .. s shaped drag link and the knuckle block (Like it sounds like you have) you may consider a hi steer kit.. I hear the objective, if you continue to use the drag link you have now, is to keep it as level with the ground as possible??
07-27-2009, 09:36 PM | #3 |
I only have the u shaped steering arm that bolts to the knuckle that came with the lift. Where can i get info on different setups like the high steer
07-27-2009, 09:50 PM | #4 |
Bloodied Knuckles
there is good tech on this site if you search.. here is some info of the last histeer/crossover steer setup I saw http://67-72chevytrucks.com/vboard/s....php?p=3429761
07-27-2009, 09:58 PM | #5 |
Bloodied Knuckles
07-28-2009, 01:59 AM | #6 |
the pollock
hey how much play is in your steering,
i know i NEED a steering arm.. but the majority of my "slop" was from my powersteering not being "tight" there is a locked adjuster nut on the ps itself you can adjust in to firm it all up again
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
08-03-2009, 08:54 PM | #7 |
not sure how much play i have but i will try to tighten that up and see if it helps
08-03-2009, 11:00 PM | #8 |
Have you checked the wheel bearing nuts. I've seen them come loose on quite a few trucks and that really makes the truck wobble going down the road. Just my .02
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
08-04-2009, 06:47 AM | #9 |
If it was mine, I would check:
Ball joints tie rod ends drag link ends wheel bearings steering box steering box bolts frame where the box mounts(cracks) rag joint Also, those 15.5" wide tires are a bear if the road has a groove worn in. A steering stabilizer would help that.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-04-2009, 09:12 PM | #10 |
Are you saying that on level smooth pavement it wanders, or when you go over bumps/dips? If it is the later, (which is probably the case) you really need crossover steering to correct. Any other slop in the system will be magnified by the bump steer.
Drag link should be parallel to the ground, but with that much lift you are going to feel it w/o a x-over setup.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
08-17-2009, 05:15 PM | #11 |
The truck does fine on smooth flat pavement its when i hit a bump or get on a road that has grooves from the heavy semi's that it jerks left or right. it sounds like i need the cross over but i only take it in the sand or on the road there's not much rock around here and it doesnt see much mud so is it worth it? everything seems to be tight underneath. The sway bar bushings are a little wore out so that might make a little difference. i was told that if i lowered the sway bar that would help, any ideas on that? will the crossover steering correct the problem on the grooved road with the wide tires? Thanks for all the help guys.
