07-28-2009, 11:56 AM | #1 |
OG
Wheel Offset & BackSpacing 101
Wassup Guys! Was just wondering if it was possible if we can get a topic dedicated to Wheel Offset and BackSpacing. I know its been on alot of peoples minds lately including mine. And I wanted to see if someone can clear up the understanding of Wheel Offset and Back Spacing. Here are a few questions that I have.
1. My current project im doing 22x9.5 Front & 24x10 Rear-->rear backspacing 6.21 & front backspacing is 5.96-->question is will the rear wheels stick out or sit further in with a Ford 9 Inch Rear 58inches long 31 spline? 2. What size rear spacers would I need to make this work? 3. Do I need spacers for the front as well? These are questions that I need help answering hopefully someone can answer these and give me a clue of a better understanding. |
07-28-2009, 05:14 PM | #2 |
OG
Re: Wheel Offset & BackSpacing 101
Anyone wanna chime in anytime!!!
07-28-2009, 10:58 PM | #3 |
True Addiction
I believe the 58" width rear-end will pull your wheels in towards the frame, compared with a GM rear. Making your overall width narrower. Is the front all original, i.e. ( A-arms, spindles, crossmember)? I would think the wheel width, offset, would be ok. This all depends on height of suspension, and what type of set-up are you running out back? Stock trailing arms?
RCC |
07-29-2009, 05:42 PM | #4 | |
OG
07-29-2009, 12:28 AM | #5 |
67-72 parts collector,…
Look here for a ton of info:
http://tires.tirerack.com/tires/Backspacing Also,... what vehicle are you working on? Is the 58" measurement backing plate to backing plate? Or from the wheel mounting surface?
07-29-2009, 07:51 AM | #6 |
and a few others
There's a lot of info out there.
one search A lot of wheel manufacturers have calculators on their website.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
