01-08-2003, 05:09 PM | #1 |
ZZ502 and Headers
Has anyone had any luck finding headers that will fit a new ZZ502 by cleasing the head bolts. I called Hooker and they said that you have to grind the flange off of the header to get it to clear.
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
01-08-2003, 10:55 PM | #2 |
So Many Ideas, So Little Money
I didn't know they were differnt from other big blocks
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
01-08-2003, 11:01 PM | #3 |
what is different from the "standard" 502 my boss has one in a GTO with hooker ceramic headers .
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-08-2003, 11:37 PM | #4 |
The ZZ502 has oval port aluminum heads. The angle of the head bolts don't allow enough room for the flange to sit behind them.
