07-30-2009, 06:50 AM | #1 |
this been a prob for others??
headers fitting with clutch linkage??...have not put them on yet but tues we will see what happens.
Paul"Give old trucks a second chance" |
07-30-2009, 07:17 AM | #2 |
Re: this been a prob for others??
Yes, in general if you have straight rod from the clutch pedal to a straight bar on the top of the z-bar between frame and engine, you may need to bend both to get to fit.
Best plan is an offset pedal rod , common on 68 and newer with a matching offset built ito the top bar on the z-bar. You may need to change the mount on the frame also as that setup is about 3/4 wider than the non-offset type. Pretty much talkng about an original V8 2wd installed in the "correct" forward position. If you are/have replaced 6 banger with a V8 and left it in the rear position or it is a 4x4 then there are different combinations that will work too. Main thing is the offset rod and bar used in the factory setups, I think they went to that offset when the big blocks were made avaiable in 68.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
07-30-2009, 07:31 AM | #3 |
Great info GM. Ill have have fun with this im sure....just hope they fit. will be well worth the effort in the end. thanks a bunch.
