Old 07-30-2009, 01:35 PM   #1
Yellow76
Yellow76's Avatar
SBC build
I have a 76 2wd short bed chevy that i want to put a 350 in, it has 194 heads,flat top pistions,edelbrock intake and a mild cam i dont no what kind of carb im going to put on it im thinking a holley 650. I want to no about what kind of horse it will have and if you no what kind of 1/4 mile time.Thanks
Yellow76 is offline   Reply With Quote
Old 07-30-2009, 03:45 PM   #2
78BO
78BO's Avatar
Re: SBC build
I don't think there is enough info to guess what HP it would give you. What type intake, lift of cam, and compresion ratio? You can look at some of the create motors to get a peek at what you might get. I was going to build my old 350. I was shotting for 400hp. But buy the time you do the machine work, buy the parts put it all together it would have cost a whole lot more then the 383 engine that blueprint engines sales. Jegs has them for just under 3k. I think the old 300 hp vettes had the flat tops and aluminum intakes.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 07-31-2009, 10:41 PM   #3
Yellow76
Yellow76's Avatar
Re: SBC build
I think it has the PERFORMER-PLUS HYDRAULIC ROLLER CAM in it (im not sure the lift) PERFORMERŽ MANIFOLD and 10 to 1 comp
Old 08-01-2009, 12:29 AM   #4
bhunt31
krazy hillbilly from Kentucky
bhunt31's Avatar
Re: SBC build
What 1.94 heads are you running? The Vortec heads were 1.94s, but they had 65cc chambers and incredible swirl pattern creating a good 20hp better than normal 1.94 heads. That's gonna make a difference. If they're regular old 1.94 heads like 400 heads, a good baseline is gonna be around 325-330hp if it's tuned well, if they're Vortecs you might see 350hp on a good day. 1/4 mile times are going to be dependant on the driver. Could range anywhere from high 13s to low 15s. My suggestion to you is that if you want close to 400hp or 12s that you go get a 3.75" stroke crank from Scat and some pistons to suit the crank to keep compression around 10:1. I've built a 355 that put down 447hp, but it's not easily done, nor is it cheap to do without knowing where to source parts from. I got lucky and just happened to have a set of 461x castings laying around to use on it, and it still cost me $3K to build it. 383 conversion is always the best idea when it comes to hp production on a 350. I only built that one cuz it was a dirt track engine in a class that didn't allow 383s, then the guy never paid me for it, so I put it in a 69 shortbed and annouced it's presence with 8K RPM drive bys.
1969 Chevy CST/10
"Old School lives and breathes in the heart of a chosen few "
1984 Chevy C10 Silverado
"Life, Liberty, and Ford's Pursuit of Chevy taillights"
You say "Obsessed with my trucks" like it's a bad thing
bhunt31 is offline   Reply With Quote
