Old 01-08-2003, 10:00 PM   #1
72PicKuPmAn
removing stepside fenders...
I was taking my bed apart on my stepside and I was wondering the best way to get the fenders off because when I tried to remove one of the screws it started to strip so I stop. I thought I would ask how you guys get your off before I tried anything else.
Taylor
'72 S/S Chevy- in progress
72PicKuPmAn is offline   Reply With Quote
Old 01-08-2003, 10:15 PM   #2
My bed sides were shot, so I took my grinder with a cutting wheel and ground off the heads, then yeanked them off. I tried on a few to use a rachet set with the screw head, but the 30+ year old screws kept striping out.
On my replacement bed, I cut the bolts from inside the step fender (grinder again). Got to be carefull so you don't damage the fenders. Don't know any other way myself.
Old 01-08-2003, 10:19 PM   #3
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
ya i had to grind my bolt heads off as well for the same reason as palf70step...those old bolts are tuff cookies
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 01-08-2003, 10:24 PM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
If you have access to a welder you can place a large nut over the screw head and weld it in the center, the heat from welding will help break the bond and then just use a ratchet or wrench to remove.
BLAZERMAN is offline   Reply With Quote
Old 01-08-2003, 10:26 PM   #5
Mudder
Mudder's Avatar
I used a vise grips on the head and twisted them off.
Mudder is offline   Reply With Quote
