07-31-2009, 04:56 PM | #1 |
67 cab on 72 frame
Will a '67 gmc cab bolt up to a '72 chevy frame ? Are they the same except the back window ? Thax!
07-31-2009, 05:46 PM | #2 |
Re: 67 cab on 72 frame
yes they will bolt up fine
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
08-03-2009, 08:29 AM | #3 |
08-03-2009, 11:42 AM | #4 |
08-03-2009, 11:50 AM | #5 |
Member #1049
Yes it will bolt up fine.. yes you can use the 67 clutch pedal assembly..
the two major differences are the 67 has a throttle pedal with a rod and the 72 has a cable.. and the emergency brake assemblies and front cables are different |
08-03-2009, 01:01 PM | #6 |
08-03-2009, 04:05 PM | #7 |
its all about the +6 inches
you'll probably want to keep the bolt in high hump floor board from the manual truck... this is assuming 4 speed and not 3 on the column.
08-03-2009, 04:12 PM | #8 | |
it was a 3 on the tree.............i put a car 4speed in ! The collar was so bad & i hate 3 on the tree ! I've got a 5speed from an '85 z28 i'm planning to install. |
