rear end question
I have a 1970 C-30, 292, 4 speed, and a very low geared rear end. She tops out about 55 mph. What are my options for gaining more speed? 5 speed tranny? If I change gears in my rear end will I lose hauling capacity? My Dad said he heard of an outfit you can bolt on the back of the tranny to do this, any one heard of any thing like that?
67 C50 dump truck 69 C10 LWB 70 C30 72 K5 Blazer |
Re: rear end question
Your dad is thinking of Gear Vendors overdrive units.
your right mcclair, those babies run around $3000, gotta be a cheaper solution.
Never Ending Projects
Basically you have 3 options,
1. Gear Vendors unit or similar $$$$ 2. Overdrive tranny, manual or auto $$$ 3. Replace gears or whole axle with better ratio $$ Yep, that's about it. Good luck. BTW a good condition 292 straight 6 is a torque monster so gears won't be as much of an issue in loss tow capacity.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thanks Mike, this little 292 runs great. The guy had it rebuilt a year before he parked it.
its all about the +6 inches
technicly, it will reduce it's hauling, and pulling ability acording to GM's dated documents.
