08-02-2009, 03:11 PM | #1 |
Finally Getting There
Got the cage all done, back window in working on finishing all the aluminum and really detailing the truck, been driving it around on the streets its been alot of fun.
08-02-2009, 03:12 PM | #2 |
Re: Finally Getting There
pics should come up
08-02-2009, 03:13 PM | #3 |
more
08-02-2009, 05:02 PM | #4 |
Awesome!
Can you provide details regarding rear tire make and size, rim size and back spacing, axle width (Moser P/N's etc), mosier axle housing(???), rear brake option, any modification to frame or axle bump stops, any issues with brake cable or hose interference with rim etc, source and P/N for ebrake cable, p/n and source for tubs, and finally, how much space do you have between the wheel and the frame/sheet metal. Pictures would greatly be appreciated. Mocking all the stuff up is expensive and am trying to minimize cost on my end. Thanks! Last edited by gene_ensor; 08-02-2009 at 09:47 PM. |
08-07-2009, 08:48 PM | #5 |
Sorry it took me so long to get back to you, i have busy with work and school my day starts at 6am and I don't get home till 11pm its been crazy. The tires are Mickey Thompson 29x18.5, on weld racing 15x12 rims, with a 7.5 inch backspacing, the rearend is a 12 bolt out of a 79 camaro it has wilwood 4 piston caliper brakes, richmond 3:73 gears, eaton posi, bearing support pan, and a set of axles. I have about an inch and half between the tub and the tires. Its all stock suspension just drop coils and shocks.
08-07-2009, 09:35 PM | #6 |
Excellent! If you ever get your tires off, I would be very interested in the axle width.
