08-02-2009, 06:05 PM | #1 |
72 BB C30 Super LongHorn
1973 Chevy C/20 Quadrajet part # ?
I am having to go and rebuild my motor. I realize that the carb on my motor isn't the original one. I am trying to determine which correct Quadrajet part # I need to make it correct again. My C/20 is a factory 454 truck. I have narrowed down the # to fall into this group: 7043200 - 7043212 I found one as : 7043207 as used on all transmissions with a 454 that year. I THOUGHT that all ending in an ODD # was for a Manual Transmission. Does anyone here have a true listing for the correct used Quadrajet Carbueretors for the 1973 year application??? Help
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
08-02-2009, 06:46 PM | #2 |
Real Projects never die
Re: 1973 Chevy C/20 Quadrajet part # ?
my dads truck is a 73 350 with a 4 speed all original untouched, auto trans did differ from manual, and i believe the 454 would have a bigger carb than the 350 and different part number. I do know, almost 99%, that 73 carbs are all by themselves, then 74 (we have a few trucks, 2 73s and like 3 74s, all 350s) , and then 75-79ish (at least on the heavier half tons and up, non emissions)
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
08-03-2009, 12:38 AM | #3 |
73 454 c-10/c-20 auto, 7043200, 73 454 c-10/c-20 manual, 7043201, 73 454c-20/c-30 any trans, 7043207, 73 454 c-20,c-30 calif. any trans. 7043507 hope that helps
08-03-2009, 01:01 AM | #4 | |
I was reading, only a suggestion, that the 7043207 was a 650-750 CFM. The 7043200 was listed as an 850 CFM. This gets me tangled. How do we actually determine how a Quadrajet is in actual CFM? There must be a process to determine CFM for each Quadrajet. Just to clarify, my desire here is to get the correct CFM and the correct part numbered carbueretor for my truck.
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 08-03-2009 at 01:02 AM. Reason: CFM clarification |
08-15-2009, 08:44 PM | #5 |
I located a 7043208 , seeings I dont see to much about this part number.... so I bought it.
I still am seeing these 7043200 units around alot. Anyone who can add to this???
08-15-2009, 10:23 PM | #6 |
the 7043208 came on the 1973 350 in the c-20/c-30/k-20/and k-30 according to my books. i have been thinking about your question about cfm of these carbs. i can't find any way to find a listing of cfm on q-jet's there used to be a place in phoenix called C.W.CARTER that had all carb parts and info but i don't know if they are still there. i don't know if this will make any sense,but here goes, if a carb is on a heavyduty truck that is built for lowend torque then it would not need a high cfm carb. but a light duty truck that is built more for higher speed and rpm the factory would use a higher cfm carb. so if that make any sense then the carb # 7043200 auto. trans & 7043201 manual trans. which came stock on 73 c-10/c-20 would be a higher cfm than # 7043207 which came stock on 73 c-20/c-30 trucks, plus the # 7043507 which came on all calif c-20/c-30 trucks would be total junk because of cali. smog rules . i don't know if this make's sense or if the heat has gotten to me. it is probaly the heat. see if you can find c.w,carter. Jim i just found the number to cw carter 602-258-3929 call them they should be able to answer you question's
08-02-2009, 07:24 PM | #7 |
1973 454 c-10/c-20 auto 7043200 ,73 c-10/c-20 454 manual 7043201, 73 c-20/c-30 454 any trans 7043207,thats what my book shows, hope it helps, jim
08-02-2009, 07:32 PM | #8 |
It's a start Thanx!!!
As I recall, up to about 73/75.... All those that ended with the 200, ie: 7043200, I think, were warranty or replacement versions. I could be wrong...
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 08-02-2009 at 07:33 PM. Reason: spelling |
08-02-2009, 07:44 PM | #9 |
I just found this listing:
1973 Rochester Quadrajet 4MV Carburetors 7043200 7043201 7043202 7043203 7043207 7043208 7043210 7043211 7043212 7043213 7043215 7043216 How to ID / Read The Part Numbers: Example: #70 4 3 2 0 0 EH 0742 70 - Prefix code. "70" will appear on all late '60's Rochester Carburetors. 4 - Decade produced. ***2 - 1960's ***3 - 1060's with A.I.R. ***4 - 1970-1975 ***5 - 1976-1979 ***8 - 1980's 3 - Year produced. 3=1973 2 - Model 0 - Monojet (1 bbl) Federal standards ***1 - Two jet (2 bbl) Federal standards ***2 - Quadrajet (4 bbl) Federal standards ***3 - Monojet (1 bbl) California standards ***4 - Two jet (2 bbl) California standards ***5 - Quadrajet (4 bbl) California standards 0 - Division. 0, 1, and 2 all indicate Chevrolet. 0 - Transmission ***Even numbers - Automatic Transmission ***Odd numbers - Manual Transmission EH - Customer code. 0742 - Date Code Now, which one is correct for my truck
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 08-02-2009 at 07:58 PM. Reason: Info add |
