Old 08-04-2009, 09:57 PM   #1
drewfever1020
can it be my heads?
ok i got a 350 chevy small blcok with a small 465 cam lift!
when i first put my cam my truck ran fine not getting hot at all!
then one day it got hot on me!
so i put in a procomp full core radiator and i put in a new water pump and a new thermostat for 160, but its still gets hot!
i got an electric fan with a switch which i am going to upgrade to no switch soon!
but can it be my heads? i know my engine is good !
do i need new heads?
drewfever1020 is offline   Reply With Quote
Old 08-04-2009, 10:40 PM   #2
CPNEJR
CPNEJR's Avatar
Re: can it be my heads?
try flushing the system real good. and not with the quick stuff do it with the stuff you need to run through the system for 20 min. we had a similar problem on our work truck it would get real hot real quick. once i did this we haven't had a problem.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 08-04-2009, 11:13 PM   #3
drewfever1020
was is it called?
Old 08-05-2009, 08:46 AM   #4
Ole Blue 68
Ole Blue 68's Avatar
1) Make sure your temp gauge and sensor are accurate. (My wire disconnected from the sensor once and came to rest on the header. Sent the gauge through the roof)
2) You might want to go with a hotter t-stat.
Ole Blue 68 is offline   Reply With Quote
Old 08-05-2009, 09:06 AM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
If it suddenly started getting hot then the first thing to check is the bottom radiater hose. Grab it and squeeze it and if it is ridgid,fine.If it collapses then it is NFG and you should replace it because the suction from the water pump will collapse the hose,restricting coolant flow.There should be a coil inside the hose that keeps it from collapsing.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-05-2009, 09:09 AM   #6
drewfever1020
i had a 180 thermostat and it still went to 200 when i was at a stop light for a few minutes!
my hoses are good i know the coolant is flowing through cause i have checked it before!
Old 08-05-2009, 09:19 AM   #7
drewfever1020
when i squeze the hose does the truck have to be on? i squeezed it right now and the trucks off and it did collapse real easy!
Old 08-05-2009, 09:27 AM   #8
drewfever1020
i dont have a shroud my fan blows really strong.
no my temp doesnt level out it keeps going higher!
Old 08-05-2009, 09:31 AM   #9
68Stepbed
68Stepbed's Avatar
I have the same issue. My engine has run hot since I installed it. I bought my engine new(GM 260hp crate engine) along with everything else to swap it out. I had a brand new radiator, hoses, belts, wp, fan, fan shroud, t-stat, etc. You name it, it was new. It's always run hot. I've replaced everything at least once. I even ditched the new 3 core rad. for a 4 core and still gets hot in traffic. Just recently, I noticed it wants to run betwwen 200-210 while driving, and still heats up at a light.
I've narrowed it down to it being in my heads.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-05-2009, 09:34 AM   #10
drewfever1020
thats exactly how mine is
Old 08-05-2009, 09:42 AM   #11
Ole Blue 68
Well try to rule out all the simple things first since heads are an expensive proposition.
That lower rad hose doesn't sound too good but you can confirm it by checking it while its running. Let it warm up for a while and then hit the throttle (or get a friend to hit the gas pedal) while you keep an eye on the hose.
Also, that lack of a shroud could be a problem too.
Old 08-05-2009, 09:48 AM   #12
drewfever1020
so your saying when the truck is runing the hose will collapse when ever i hit the throttle?
Old 08-05-2009, 09:55 AM   #13
Ole Blue 68
not exactly but getting the rpms up will trigger a collapse if the hose is bad.
Old 08-05-2009, 09:56 AM   #14
dznucks
dznucks's Avatar
when you increase the engine rpm you are also increasing the flow of the water pump. when you increase the flow in a system you are going to create a vacuum. this vacuum could be collapsing the hose.
the shroud is very important too. when i put my enigne in i didnt put the shroud on at first during the break in period. i thought the fan was strong enough. the problem with no shroud is that the fan is pulling air from other places, not through the radiator cooling the coolant. yes its blowing air across your engine, but not pulling it through the radiator.
dznucks is offline   Reply With Quote
Old 08-05-2009, 10:02 AM   #15
drewfever1020
i will consider getting a shroud soon!
and im going to check the hose later today, but for now im off to work! thanks guys!
Old 08-05-2009, 10:03 AM   #16
70k52wd
Blaze-Air
70k52wd's Avatar
Also, the reason you want to go back to a 180 or even 195 stat is it keep the coolant in the radiator longer to cool it more. The 165 is cycling to fast. It's not letting the coolant stay where it needs to be long enough.
70k52wd is offline   Reply With Quote
Old 08-05-2009, 12:09 PM   #17
mclairmo
I've had a hell of a time keeping my 396 cool but finally fixed it. I fabbed a sheet metal shroud to add to my Flex-a-Lite Black Magic fan so that the fan pulls air through the entire core. I'm running a new 4 row brass/copper radiator. I also sealed the radiator to the core support with foam weatherstripping so the fan would not pull hot air in from the engine compartment and through the radiator. You want only cold outside air going through the radiator. I have a new Procomp aluminum water pump and I'm running a very small water pump pulley, less than 6 inches in diameter and a very large crank pulley, almost 8 inches in diameter. The pulley sizes are very important for keeping the water pump flow high enough at idle. You need the water pump pulley to be smaller than the crank pulley, forget about underdrive pulleys, they suck. I am also running the vacuum advance, which helps to keep the engine cool. I also have ceramic coated headers to keep underhood temps down a little, as opposed to non coated headers. Exhaust manifolds would be even better. I run a 180 degree T Stat and the engine idles at about 190 degrees all day long now. Used to climb past 220.
mclairmo is offline   Reply With Quote
Old 08-05-2009, 12:31 PM   #18
cdowns
cdowns's Avatar
r u using antifreeze? just plain water will run hotter than the proper 50:50mix of antifreeze// and 200 in texas in the summer aint really very hot
Old 08-05-2009, 12:35 PM   #19
WorkinLonghorn
That's right.That's only 5 degrees hotter than the minimun as set by a stock 195 deg.therostat.
Old 08-05-2009, 12:54 PM   #20
Ole Blue 68
200 wouldn't be bad but it sounded to me like he meant it hit 200 and kept going.
Old 08-05-2009, 02:45 PM   #21
sleepertruck72
sleepertruck72's Avatar
Is your radiator cap also new ? May be too high of psi cap ? along with something else like the lower hose ...
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 08-05-2009, 04:30 PM   #22
mclairmo
Antifreeze does NOT transfer heat as well as plain water. Antifreeze is to prevent the water from freezing, to provide a lubricant for the water pump bearing/bushing and to prevent rust. The engine should actually run cooler with 100% water. I ran 100% water with Water Wetter and it was cooler than with 50/50 antifreeze and water. An engine is fine to run at 200 degrees or even 210. If it goes above, then you need to start to worry. I don't think the radiator cap pressure rating will truly affect what temp the engine runs at. The cap rating affects the boiling point of the water. Raise the pressure, you increase the boiling point of the water which prevents a boil over. I have a 20 lb rad cap and it works great. This is why race cars use higher rated caps. However, the increased pressure can start to blow out weak cooling components, like hoses, radiators, etc.
Old 08-08-2009, 04:51 PM   #23
drewfever1020
ok i bought a new thermostat 180 and another fan!
so i got one fan pushing and one pulling!
i put the new thermostat on already!
the truck was running for about 12 min and it got to 200, i think i got a real problem here!
my hoses are good i checked them!
everything practictly brand new!
waterpump
thermostat
2 electric fans
im sure its my heads rite?
Old 08-08-2009, 05:27 PM   #24
sleepertruck72
Are you sure the temp. gauge is good ?
72 C20 Longbed
05 1500 Z71
Old 08-08-2009, 05:28 PM   #25
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you need to verify that your engine is that hot.
Since you are giving numbers, and not saying "the H on the guage" I'll assume you have an aftermarket guage hooked up.
Is this an electric guage, or mechanical?
