Old 08-06-2009, 07:47 AM   #1
KEL
72 GMC
KEL's Avatar
Carrier Bearing
I realize it varys, but what are you guys paying for
carrier bearing replacement ?
KEL is offline   Reply With Quote
Old 08-06-2009, 11:56 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Carrier Bearing
I think I had new u-joints installed, the driveshaft balanced, and a new carrier bearing install for like $100....I took the carrier to the DS shop that I think I ordered from Orange County.....(it's been like 3 years since I did this!!!)
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 08-06-2009, 06:44 PM   #3
70Custom10Nut
70Custom10Nut's Avatar
Re: Carrier Bearing
It's really pretty easy. Get the bearing from any repuetible auto parts store. (I used a Timken bearing) Take you driveshaft out with the old one and take it into the two pieces. Then you have to gently remove the old bearing collar without gouging the driveshaft. then slide the new one on, and reassemble. Really pretty easy. If you trust yourself you can use a torch to heat up the collar and it will come loose easier, but be real careful. A little bit of on your back work and a little patience will save a good chunk of change. Let us know
70Custom10Nut is offline   Reply With Quote
