View Poll Results: What should I do about my pickup box? | |||
Purchased bed liner (Duraliner/Pendaliner) | 1 | 2.33% | |
Take it in for a Rhino liner | 32 | 74.42% | |
DIY spray on/roll on bed liner | 9 | 20.93% | |
Grab a paintbrush and some Rustoleum and git 'er done | 1 | 2.33% | |
Voters: 43. You may not vote on this poll |
08-06-2009, 11:52 AM | #1 |
Poll: Pimp my bed!
Everyone has an opinion and I'm interested in yours;
Here is the object of our attention: The question is: what do I do with this? Stick a box liner in? Paint it myself? I'm interested in your thoughts. If you chose "Install a bedliner" let me know where you think they might be available, since I have not been able to find one for our bodystyle. Note: I did not include a tonneau cover/hard cover as an option because of the bed mount spare sticking up. I'd like to limit the options to the $300 - $400 range. Thanks, K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-06-2009 at 11:54 AM. |
08-06-2009, 12:06 PM | #2 |
a fool with no money
Re: Poll: Pimp my bed!
for a daily driver... professional spray liner all the way! can also be done in colors if you don't want the "black box" look...
btw... been following your intro. post... I'm envious of your career.
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
08-06-2009, 01:19 PM | #3 | |
I should have mentioned my anticipated usage(s): This is my daily driver, which consist of commuting 9 miles each way to my office. I don't do very much "heavy" hauling, but I do haul stuff occasionally. The occasional air compressor (...like last night). Lots of trips to Home Depot. I could see hauling landscape materials (rocks, wood chips) maybe once more before I die. I do a fair amount of trailering, which means throwing accessories (like wood blocks, tiedowns, maybe even the trailer skids) in the back. It will probably haul a bare engine block or maybe even a complete engine assembly a few times. You can't tell from these pictures but I am usually pretty easy on equipment. I am not characterized by banging stuff up, tearing stuff up or dragging it across the bed rails. I think that's about it. Thanks again, everybody, for your input and keep 'em coming - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-06-2009 at 01:22 PM. |
08-06-2009, 01:21 PM | #4 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-06-2009, 12:09 PM | #5 |
It'd be alot cooler if you did
Keith-
I have never seen good result from the roll on kits, the liners trap water and rub the paint off... so my vote would be to take it in, or DIY spray on liner. The guns can be had for less $100 on eBay, and any other materials you need can be had from AutoBodyToolmart.com . This is the route I plan on going when I get my bed done. Take it easy on this beautiful day! |
08-06-2009, 12:13 PM | #6 |
Garage wrench
I say get it sprayed with Red. Body color rhino liner/line-x liner looks awesome
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
08-06-2009, 01:10 PM | #7 |
I believe SEM makes a liner that you can add your exact color to.
08-06-2009, 01:22 PM | #8 |
All of the SEM products I've used have been top notch.
What look do you like the best? Black box or? If you do get it prof done, I would recommend LineX over Rinho. Just my experience. But they can both be pricey. Personally I plan on trying my hand at making a tonneau cover since I haul boxes alot. |
08-06-2009, 04:19 PM | #9 |
I would either do a professional spray-in bedliner or if you have the euipment, by all means, spray in your own.
08-06-2009, 05:56 PM | #10 |
I would first suggest LineX. I just don't like the drop-in liners. After all the work you have done, I think it would not look as good. My dad just had his new F150 LineX'd and it was almost $500 Like Tony said they have a better looking product than Rhinolining does though. It may be a little more expensive, but they do have a lifetime warranty.
My cousin bought a kit from O'Reilly that Dupli-Color has. Really pretty cheap. I don't know how well it works for a bedliner, but he sprayed the underside of his Camaro with it, and has used it in other areas as well and it turned out really nice. |
08-06-2009, 06:35 PM | #11 |
Badass
the guy that had my truck grabed paintbrush and some Rustoleum.lol its all chiping and falling all apart.dont do any heavy healing but i do put bmx bikes in the back 2times a week
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
08-06-2009, 08:15 PM | #12 |
>130dB Moderator
I have a spray on liner and I love it. For a daily driver, it's dam near perfect. I suggest getting the Rhinoline brand personally because every dealer sells a "conditioner" that will make it pretty again. I have to resort to tire shine sprays for shows, then power wash the bed after its over so it doesn't discolor the liner.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. Last edited by AceX; 08-06-2009 at 08:16 PM. Reason: I don't know how to read... |
08-06-2009, 09:06 PM | #13 |
Official Site Guitar Shredder
Every though of Als. Liner...Its what I did...And IMO its better than any (pro) liner...And for the record...I sprayed Rhino for a few years....
08-06-2009, 10:10 PM | #14 |
I have been thinking about the Al's liner also. Just have too much other stuff ahead of it on the ever growing list of wants!
08-06-2009, 10:45 PM | #15 |
Happy to be here
*BarryB's Coatings* * August Special * *FREE SHIPPING* BarryB's Coatings offers Al's Liner Urethane/Acrylic Coating System. This is designed to be the markets first and only professional grade urethane coating for Do-it-Yourselfers. Be it Truck Bed Lining, Undercoating, Interior Coating, Chassis Lining or just General applications around your Shop and Home, BarryB's Coatings has protection no matter where or why you use it -For the month of August- BarryB's Coatings will be offering free shipping anywhere in the Continental U.S.A. Just buy one kit of material, and one spray gun (retail price 150.00) From now till August 31, it will be shipped for FREE. **To make your order go here- LINK**
08-07-2009, 12:04 AM | #16 |
I have car A.D.D.
A buddy of mine did Al's liner on his Samurai. Turned out great. As far as professional spray in liners, I like Reflex alot. It is not available everywhere, but it always holds up better than most. It stays more pliable and holds its gloss and colors well. If you are going to pick a pro spray in and can't find that get Line-X. Out here in the high country where the UV rays really pound stuff, Line-X seems to last longer than Rhino. Rhino just gets soooo dry and brittle feeling, and that looses the purpose of the liner in the first place.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
08-07-2009, 12:34 PM | #17 |
linex
08-07-2009, 12:55 PM | #18 |
I did the roll on liner on my cj7 tub (the inside of course) It lasted 4 months before pulling up. I spent hours prepping it too.
A couple friends have their truck beds LineX'd. Best stuff in my opinion...well worth the cost and its incredibly durable |
08-07-2009, 01:06 PM | #19 | |
Thanks for the input - K
08-07-2009, 02:08 PM | #20 |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-07-2009, 02:46 PM | #21 |
I believe that it was a roll on herculiner but I don't remember. I am getting the tub linex as soon as I get the money and time to finish the jeep.
You wont be disappointed with LineX |
08-07-2009, 05:34 PM | #22 |
Kid's Mechanic
From using plastic bed liners at work I would stay away from them.Front bed panels are the 1st thing damaged in the company trucks from hitting the brakes with a generator set or an air compressor sliding during a panic stop.Man those things are slick!
08-07-2009, 10:15 PM | #23 |
The only drawback with spray in liners is when you need to shovel rock or mulch out of the back and the shovel gets hung up instead of sliding easily like it does on steel.. that probably why I wouldn't do a spray in personally.
08-08-2009, 04:28 AM | #25 |
At the body shop.
Piant it And a rubber bed mat simple E.z and cheap
