Old 08-08-2009, 11:55 PM   #1
drewfever1020
anyone got pics of 3in 4 in drop?
3in in front and 4 in back?
has anyone used brothers lowering kits?
drewfever1020 is offline   Reply With Quote
Old 08-09-2009, 12:13 AM   #2
dbmx66
Re: anyone got pics of 3in 4 in drop?
ive never even heard of brothers lowering kits.
dbmx66 is offline   Reply With Quote
Old 08-09-2009, 01:22 PM   #3
LEEVON
Moderator
LEEVON's Avatar
Here you go, 4" coil springs out back, 3" lower controls arms up front:
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-09-2009, 11:19 PM   #4
drewfever1020
thats still to high
i want go get my truck low but i dont want to have to change everything out!
Old 08-10-2009, 08:16 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Originally Posted by drewfever1020 View Post
thats still to high
That's about nearly impossible as you will have to change something to get your truck lower than 3"/4".
For instance, we just tied up lowering my '69 4.5/6" and used 2.5" drop spindles, 2" front drop springs, 6" rear drop springs, new shocks, shock relocaters, disc brake upgrade..... etc.
You could install bags without much modifaction to the current suspension, but it will require removing your springs, running lines, power, compressors, valves, tank... etc.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-10-2009, 09:35 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
thats still to high
What exactly are you trying to accomplish?
Just replacing your heated springs?
Using over a 3" drop spring in the front will cause alignment issues.
Most 3/5 spring drops will require drop shocks.
What kind of budget do you have for your suspension drop?
Keith
Convert to disc brakes.
Old 08-10-2009, 09:07 AM   #7
drewfever1020
4/6 drop doesnt look that low!
My truck is about thay low right now but i heated my springs haha
Old 08-10-2009, 09:39 AM   #8
drewfever1020
i understand im going to need drop shocks and spindles but i want a drop to were my tires go in the finders just a little!
Old 08-10-2009, 01:35 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
So you are looking for your drop to "tuck" your tires.
As lolife99 mentioned.... the next question we will have it, what's your budget?
We can direct you to a mild setup, or go all out for the wild install.
-Nate
Old 08-10-2009, 02:06 PM   #10
lolife99
lolife99's Avatar
This is my 5.5"/7.5" static drop on my '69.
I think you will need bags to get it lower. Also,... your front tires will have to "tuck" to be able to drive it this low.
Keith
Old 08-10-2009, 10:24 PM   #11
drewfever1020
a mild setup would be good!
i just want my truck to look low but good!
that staic drop looks good
Old 09-18-2009, 07:05 PM   #12
XXL
Señor Member
XXL's Avatar
You need to figure out specifically what you want, how much you're willing to spend, then come back and ask your questions. Right now, you're just generating posts from people trying hard to help, but not being able to read your mind.
BTW, there is a LOT of information in this forum if you'll take a few hours of time to read the various threads that are already here. You may even find the answers to the questions you're having trouble formulating in this thread.
XXL is offline   Reply With Quote
Old 09-20-2009, 04:04 PM   #13
Ben IV
lolife99 love the stance, what size tires are you running? and what shocks?
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 09-22-2009, 02:51 PM   #14
royo
royo's Avatar
1.5 coil cut from bb springs ece drop spindalls
4 in drop spring in back with 2in block
nickle and dime
royo is offline   Reply With Quote
Old 09-22-2009, 02:54 PM   #15
royo
royo's Avatar
looks like this now porterbilt style still underconstruction
nickle and dime
Old 09-22-2009, 06:31 PM   #16
lolife99
lolife99's Avatar
I'm running 215/70-15's up front and 275/60-15's in the rear. Front shocks are Belltech shocks I had,... and the rears are KYB"s from ECE.
Keith
Old 08-10-2009, 10:36 PM   #17
lolife99
lolife99's Avatar
drew,... my drop includes 2.5" drop spindles, 3" drop front coils, all 4 drop shocks, shock relocators for the rear, 6" drop rear springs, adjustable track bar, 1.5" drop blocks and a bolt in c-notch.
ALOT of stuff to change.
If you have any questions,... just ask. We are here to get your truck riding low,...
Keith
Old 08-11-2009, 09:17 AM   #18
drewfever1020
were did u get that kit from?
Old 08-12-2009, 01:55 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
If you're referring to the kit lolife99 posted on his '69; he purchased the items separately from different vendors.
If you are looking for a kit which will include 99.9% of everything you will need, check out Early Classic Enterprises (www.earlyclassic.com). I purchased my 4.5/6" drop with disc brake upgrade from them, and had zero issues in installing it.
-Nate
Old 09-18-2009, 06:56 PM   #20
burke117
If I was to use 3" spring in the front and 5" springs in the back would I have alignment or any other issues? Or would I be better of doing a 2" spring in the front and a 4" spring in the rear.
burke117 is offline   Reply With Quote
Old 09-22-2009, 02:58 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You last couple of pics had me looking out the window... you had me scared there for a minute. I thought winter had come.
-Nate
Old 09-22-2009, 03:01 PM   #22
royo
royo's Avatar
That was in January lol.
nickle and dime
