Old 08-11-2009, 10:27 AM   #1
vegaschevy
holly carb for sale this one what i need?
Is this a carb that will work on my stock worn out tired 72 350? i believe i need a vacuum secondary with electric choke, is this right?
http://lasvegas.craigslist.org/pts/1313145962.html
vegaschevy is offline   Reply With Quote
Old 08-11-2009, 10:30 AM   #2
vegaschevy
Re: holly carb for sale this one what i need?
here is another
http://lasvegas.craigslist.org/pts/1307975219.html
Old 08-11-2009, 11:20 AM   #3
QKENUF4U
QKENUF4U's Avatar
will work fine on a stock motor....personally i wont use anything but carter AFB/EDELBROCK from now on but if your going cheap then those are the ticket.....
oh and that truck i found in bouse is a longbed 3/4t 2wd camper truck... so no go on that dream...
QKENUF4U is offline   Reply With Quote
Old 08-11-2009, 03:58 PM   #4
vegaschevy
Im picking up an Edelbrock 1406 I found on Craigslist what else will be needed to install it> THe owner said he has the adaptor plate to go onto the stock manifold. anything else I will need to do this swap?
Old 08-11-2009, 04:01 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
carb gasket, you should be able to make the linkage work if the edel comes with the linkage end attached .
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-11-2009, 05:33 PM   #6
mclairmo
I would run a Holley 4160 600 cfm with vac secondaries and elec choke. Beware of used ones. You may have to rebuild it and the adjustments may be totally off from the PO tryin to "tune" it.
mclairmo is offline   Reply With Quote
Old 08-11-2009, 05:39 PM   #7
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
If he has the spread bore to square bore adapter, you need to make sure he or you have the right bolts. You need the smooth round bolts or allen headed ones that will screw it to your manifold and regular 6 pts that will come up through the plate and that is what you will set your carb onto and tighten up.
prostreetC-10 is offline   Reply With Quote
Old 08-11-2009, 06:18 PM   #8
vegaschevy
Would I be better off startingwith s summit brand edelbrock carb? Starting with a brand new one? Will it come with other needed stuff?
Old 08-11-2009, 06:31 PM   #9
mclairmo
You'd be better off with a new Holley. I found a new one for $100 on Ebay. It was a rare once in a lifetime find, though. Seller did not post pics and it was a crappy auction description. I got lucky. The Summit brand carb looks just like the old discontinued Holley 4010 carb that was similar to the old Ford Autolite carbs. Good design, just never caught on in the 4010 for some reason. FordMuscle.com has an awesome review, teardown and install on this Summit carb. Apparently, it's made by Holley and designed by the same guy that designed the old 4010. Has annular boosters. Sounds like a good carb.
