Rochester model B blues. Please help.
Hi there, I have a 66' c-10 with a 250 inline six cylinder motor. At one time, I had the truck running but one day it decided to quit and only run if I poured gasoline into the intake manually. I checked the fuel pump and it worked fine. so i decided to rebuild the carb. after checking all my passages if they are free or not, the thing still will not run for lack of fuel. Note: I understand that you have to soak the plunger in oil for the accel. pump to work, (I soaked mine in WD-40) yet it is still not pumping properly. Have i used the wrong soaking procedure, or is there another problem i should check?
Re: Rochester model B blues. Please help.
Do you know if there is gas in the bowl? Could the needle be stuck? Just a thought.
What about the Vacuum Advance Lines?
Alot of things it could be on these old carbs make sure the rubber seal is good on the accel pump if not lubed enough it will tear when you install it . Check the float make sure its adjusted right and no holes are in it. And check the little metal filter that in where the line goes in Every kit i have every bought seems to be missing it. Na make sure you used the right gasket that seals the bowl to the top most kits come with a couple of them and they look almost the some but the wrong one will block so holes
okay. i dismantled it again and found that there seemed to be a passage above the check valve for the accel. pump, should that part of the gasket be have a hole, or is it there for a reason? Also, if it is of any help it is a model BC to be exact.
Junior Member
Yes! Some kits have a gasket without that hole. You will need to carefully make one in the gasket or order a new correct gasket.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() Last edited by ol Curt; 08-15-2009 at 09:06 AM. |
