Old 08-11-2009, 11:02 PM   #1
jojo
printing is my trade
jojo's Avatar
temp gauge questions
My temp gauge is stuck on hot and has since I got the truck. I suspect something with the gauge is bad not the sending unit. Does that sound right?
The temp gauge sending unit has only one wire connected is that correct?
In a stock set-up is the gauge connected to the circuit board on the gauge cluster or are there supposed to be wires running up to it?
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 08-11-2009, 11:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: temp gauge questions
no wires. If you have a wire, it is probably to bypass a messed up circuit board.
If the guage drops when the key is off, and pegs when turned on, then odds are, it is the wire from the sending unit to the guage (through the harness) is grounded. Look at the green wire on the drivers side head, see if it is melted on the manifold.
Old 08-11-2009, 11:30 PM   #3
jojo
jojo's Avatar
The gauge never drops with keys on or off. The wire was probably melted at one point and a repair was done because now there's a brown wire there and spliced half way up to the fire wall to the green wire.
Old 08-11-2009, 11:36 PM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I bet you are right, it probably melted at one point. But like LHM said, the guage is connected to the printed ckt board on the back. There should also be a resistor under that in between the terminals. Is that all there?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-12-2009, 01:04 AM   #5
jef5150
Inline 69
jef5150's Avatar
picture may help
jeff
jef5150 is offline   Reply With Quote
Old 08-12-2009, 02:29 AM   #6
red71cheyenne
Back in the sticks
Wow!! That pic is awesome!
2011 K1500 Suburban
2014 K1500 Pickup
