700r4 trans tunnel and crossmember?
what are you guys doing to put 700r4's in your trucks?
Re: 700r4 trans tunnel and crossmember?
Pretty straightforward-I had to move the crossmember back and drill new holes, and shorten the driveshaft 3 inches. Make sure the shaft is lined up with a dial indicator before welding. Mine was a factory auto, so I bought a Lokar kit which is adjustable enough to set the shifter correctly. The pointer is only correct at Park and L, but I think I've seen a bezel that should work, designed for the 67-72s. I believe the columns are the same diameter, so at worst, I'll have to drill new mounting holes for it.
BTW, you have to have the correct yoke. I can't remember what I used, but it's different from the Powerglide. I think a 400(?).
what did you do with all of your ebrake stuff?
Yoke is same as a TH350. I bolted mine in with a CCP trans crossmember. I started with a roller and had no motor or tranny to start with.
I havent put mine in this truck yet but my other had no ebrake stuff and it was move xmember,redrill and shorten driveshaft.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Why would the E-brake be affected by the transmission that's in the truck???
#8 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
