Old 08-12-2009, 09:00 PM   #1
1964C10
1964C10's Avatar
Firewall grommet/connector
What is the proper procedure for taking out the firewall grommet? The main one where the blinker light plug is the top half and the other main portion is the bottom half. The inside and outside portion appears to be some rubber material that has I am sure hardened up but what about the inside plug portion? I want to take it out so I can clean it up and reuse it. This is on a '64 C10. Thanks!!
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 08-12-2009, 11:55 PM   #2
Captainfab
60-66 Nut
Re: Firewall grommet/connector
I would first try and spray it with some silicone spray where the plug contacts the rubber. Then push it to the inside of the cab. If it doesn't come out with a little persuasion, I would just cut the rubber and remove the plug. You can buy the rubber grommet new and I don't think they're much $$.
Old 08-13-2009, 01:07 AM   #3
1964C10
1964C10's Avatar
I will try that tomorrow. Just so I understand, the plug is held in place by the rubber? I am trying to crawl underneath my dash to get a good look at it but I can't really see it well.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 08-13-2009, 02:05 AM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
That grommet holds one part of the plug in place, then the light harness plugs in...if your able to push the connector out of the grommet, then the grommet might colapse a bit to be removed.
You could also try a heat gun/hair dryer to soften the rubber too.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-13-2009, 09:59 AM   #5
1964C10
1964C10's Avatar
Thanks Chief! Btw is that the way it is designed to be removed? I am sure that plastic firewall plug has become somewhat brittle and forcing it the wrong way might break it. I will try it this afternoon, thanks again!
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 08-13-2009, 11:25 PM   #6
Captainfab
60-66 Nut
Yeah that grommet is rubber. They usually get hard from the heat in the engine compartment......and just old age.
Old 08-13-2009, 11:42 PM   #7
1964C10
1964C10's Avatar
Ok I got it out, tried pulling and pushing and all of that. Finally I took a big screwdriver and worked it out. I left some marks on the outside of the casing but nothing that will show. Even after taking it out I couldnt find a good way to do it.
1964 Fleetside LWB
1996 Camaro Z28
My build thread
Old 08-19-2011, 01:57 AM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Where can we purchase new firewall rubber grommets and wiring connectors?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-19-2011, 02:12 AM   #9
DPowers
One foot in front of the other
DPowers's Avatar
http://www.truckandcarshop.com/index.html
DPowers is offline   Reply With Quote
Old 08-19-2011, 02:15 AM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
Here's one source for the grommet. I’m not sure if you can buy the connector as a separate piece or have to buy a harness:
http://www.classicparts.com/1960-66-...ctinfo/42-106/
Old 08-19-2011, 04:20 AM   #11
dthela
dthela's Avatar
why do you need a new connector? The grommet usually comes as a kit of about 6 pieces with all the grommets. I have one and a harness if interested!
dthela is offline   Reply With Quote
