Old 08-12-2009, 11:02 PM   #1
84 400
Sb 400 club
84 400's Avatar
Thumbs down Removing a raised steering arm???
Okay got the nuts off easy enough but this little gem don't want to move. And bonus... I need to do two! Any tricks to getting one of these raised steering arm's off? I tried to heat it have been soaking it in PB and hitting it prett y good with a mini sledge. This used tapered washers right??? Is there a sweet spot to hit this at to get it off?
I am removing a 4 inch coreection one and my stock arm and putting the 4 inch on my 77.
Thanks for any input
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 08-12-2009, 11:30 PM   #2
Mudder
Mudder's Avatar
Re: Removing a raised steering arm???
I think you have to hit it harder. There has been some ideas passed along here in some other threads but not sure how far back they are.
Mudder is offline   Reply With Quote
Old 08-13-2009, 01:14 AM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
the only way i got mine off was PB brother...
and my mini sledge.. it was infact impossible.. and it reallllly sucked..
but i got it allright
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-13-2009, 02:12 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Those wedges are a sob! Have you used a chisel or an air hammer to try to get them to walk out? Worse comes to worse, weld a nut to the stud and use a healthy impact or breaker bar and pipe and try to back the stud out. Another thing that works sometimes is use a hammer on the opposite side as you are hitting on. Use this hammer and just press firmly with it. Use your other hammer and beat the side you were beating. It helps keep impact in the part you are hitting. Works pretty good usually.
Ryan
1969 Chevy milk truck
Old 08-13-2009, 09:45 AM   #5
70 beast
Certified Hobbiest
70 beast's Avatar
ive taken a few off in the past few weeks and what seemed to work the best was to have an extra hand pry up on it somehow, while you hit on it. then, (granted it moved somewhat) the acorn washers will be exposed just enough to get a set of plyers in there to spin em and taken em out. then the rest is down hill from there.
dont know if its the right way but it worked for me numerous times.
70 beast is offline   Reply With Quote
Old 08-13-2009, 11:20 AM   #6
mickeymouse
Whack it on the side of the arm, where the cast numbers are.
mickeymouse is offline   Reply With Quote
Old 08-13-2009, 01:17 PM   #7
Oilbrnr
Oilbrnr's Avatar
Make sure to *back-up* the other side of the arm that your hitting with the sledge. I used a dolly for body work that was fairly substantial. Small sledge, don't remember the lbs. No problemo.
AZ trucks though too...
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 08-13-2009, 08:52 PM   #8
84 400
Sb 400 club
84 400's Avatar
it has not moved at all. where are these cast numbers?? I am trying to removed the raised first then on to the one on the truck. I have taken some hudge swings at it with a full size sledge and it has not moved at all. I am thinking of just pulling the knuckle and bringing it to the machine shop.
Looked on my stock ar but did not see any numbers. Are they on the side of the arm
1985 C10 LWB Sold
Old 08-13-2009, 09:04 PM   #9
whiskeydented
whiskeydented's Avatar
I just removed one this weekend. I heated it and then splashed it with water and pounded it with a 3 pound hammer. Once I saw it had moved a little I hit it back on the knuckle and grabbed the cone washers with pliers and unscrewed them. Then pounded some more with the hammer. It was twenty minutes of hammer swinging and it was off. Not easy but doable.
whiskeydented is offline   Reply With Quote
Old 08-13-2009, 09:46 PM   #10
mickeymouse
Post a picture of it.
Old 10-16-2009, 08:54 PM   #11
dan04103
dan04103's Avatar
Talking Re: Removing a raised steering arm???
I decided to post this here instead of making another redundant thread concerning this topic, but I JUST got mine off!!! Wow, easily the hardest thing I have done on this truck. The only way I could get them off was to drill slots around each cone washer then by process of eliminating the washer the arm finally busted loose. It is so nice to be back to stock! Now on to the slop in my tilt column.
dan04103 is offline   Reply With Quote
Old 10-17-2009, 07:40 PM   #12
msgross
msgross's Avatar
I drilled the cones as well, but be careful not to go too deep, you'll ruin the arm...
not easy i agree...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-18-2009, 09:45 AM   #13
LONGHAIR
This is one of the toughest things there is to do on these trucks...and as far as I know, there is no nifty tool to take one off. It is purely a hammer thing, but bigger is not necessarily better though. I have had better luck with a hammer that is smaller than what you would call a sledge. Hits that are "faster and more often" seem the help. Start from the back, with the steering turned all the way to the right. Hit the arm closest to the rear stud, several quick and repetitive hits. When the sound changes, the first cone has popped, remove it before continuing. Hitting up or down on the arm doesn't do much good, the taper of the cones fights that, but it may help a little after you get one of more loose.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-20-2009, 12:55 AM   #14
84 400
Sb 400 club
84 400's Avatar
well i took mine to the machine shop and he said it would cost too much to get it off. I got the axles with the frame so I just said screw it and ordered a new raised arm. hopefully i can install it this or next weekend and get my steering back in sinc.
1985 C10 LWB Sold
Old 10-30-2009, 04:42 PM   #15
Gene
Gene's Avatar
I ordered a raised steering arm from Skyjacker, and their instructions say to hit the drag link side of the arm until the cone washers break loose, after about 10 good whacks I noticed that the front washer had came loose. I took it out then the 2nd came out and then the 3rd, even after they were all out I had to use a pickelfork at the front and a wedge at the back to wrok it loose. Really wasnt that bad after I read the instructions
Gene is offline   Reply With Quote
Old 10-31-2009, 08:40 AM   #16
LONGHAIR
Originally Posted by Gene View Post
and their instructions say to hit the drag link side of the arm until the cone washers break loose. Really wasnt that bad after I read the instructions
This is one of those "words are easier than actions" types of things. Sure, it sounds easy....but you might still be swinging until next Tuesday.
Old 11-01-2009, 12:07 AM   #17
82swampthing
82swampthing's Avatar
It took me two weeks to get my steering arm off. I used a combination of marvel mystery oil, sea foam deep creep , Heat and a mini sledge. Gotta love that northern salt.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 11-01-2009, 08:47 AM   #18
csa daddy
csa daddy's Avatar
i just seen this an i was going to say the exact same thing beating on the sides never worked always take an beat the part where the draglink hooks up ,up an down an it will eventually come loose i have cooked ball joints with torches trying to get these arms of before
csa daddy is offline   Reply With Quote
Old 11-01-2009, 03:50 PM   #19
cobinder
Everything is work in progress
cobinder's Avatar
Step 1. buy a six pack of your favorite beer. Step 2. consume 5 of said six pack.
Step 3. beat the piss out of it with a mini sledge. Step 6. When you do get the F'n thing off, enjoy your last beer.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 11-01-2009, 05:00 PM   #20
2tons of fun
get a large [1-1/8"+] deep socket.
place socket over stud and AROUND the cone, this will do you absolutely no good if the socket is pushing down on the cone.
hit the socket directly down. it will drive the cone up and you can grab it from there.
works every time.
fwiw, i have driven on a stock arm with no nuts 75ml off a trail and windy mountian road and it was still just as tight as it was when we left. [1am trail repair, coulnt get the arm off on the trail and forgot to put the nuts back on. didnt know about this trick till the next day and it popped right off]
2tons of fun is offline   Reply With Quote
