08-13-2009, 12:37 PM | #1 |
'89 3/4T 'burb front-end swap to '66 C20
I look at the restoration of my truck as two main parts: Mechanical & Aesthetics. The mechanical part being everything that's under the body & bed boards while the aesthetics are well, the rest of the stuff that makes the truck pretty.
My plan is to complete the mechanical resto first, then worry about the paint & body part. The way I'm going about this is a little different, because I drive my truck every day. Most normal people would buy their project truck, make a budget, and either buy all of the parts they're going to need up front, or tear down their truck first, then purchase the parts. Then sand blast, clean up, patch up, paint and re-assemble with new parts, engine, trans, drive line, diff, wheels exhaust cab, front clip, electrical, bed & bed wood - done! (not necessarily in that order) My approach is different for 2 reasons: 1. I don't have shop big enough to store a stripped down frame off truck for a year or so until I can finish it. 2. I drive my truck every day. The modified plan goes something like this:
I've broken the mechanical part down into 3 phases:
The Aesthetics part doesn't really break down into phases because I can do all of the work off-vehicle (with the exception of the bed because I don't have a spare one of those) and assemble it all at the final tear down. Well it's been a long time coming, but with the engine, exhaust and transmission completed like I wanted it, the time is finally here to start phase 2 of the mechanical "restoration" of my truck! My plan to upgrade my steering & brakes was to swap out a complete front suspension from a later model truck - cross member & all. Not only does this fit my modular approach to minimize down time, but it also makes it easier to avoid geometry issues and replacement parts later on. I can also sell my vintage "power assisted" steering parts at the swap meet as a complete package. Some time ago (about 4 years ago) I purchased a front end out of an '89 3/4 ton Suburban: After a not so brief intermission, (2 years recovering from a near fatal aortic aneurysm) I was finally able to complete the re-build: Here’s most of the parts I'll need to complete the upgrade: New calipers & pads, new outer tie rod ends, new dual mastercyl/brake booster kit adapted for a '66 Chevy truck, a re-manufactured p/s box from the '89 3/4 ton 'burb, new sway bar bushings, brackets, good used pitman arm (89 burb), good used inner tie rod ends, good used idler arm/center link and good used sway bar brackets for front cross-member. The huge 1-1/4" sway bar, the re-man p/s pump and the REZ adapter kit aren't pictured. I still need to purchase p/s hoses, brake lines for the fronts, and some new dust covers for the inner tie rod ends. The plan is to remove the front clip of my truck intact, jack up the frame, suspend the engine, remove the existing front-end (cross member & all) clean & POR-15 everything, then install the new cross-member, the master cylinder, p/s box, p/s pump and all the lines. Then put the "dog house" back on as it was - well, that is except for new isolators under the core support.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
08-14-2009, 09:12 PM | #2 |
Re: '89 3/4T 'burb front-end swap to '66 C20
whew! you guys really know how to bury a post!
08-14-2009, 09:55 PM | #3 |
Resistance is Futile
........post the pics first. J/K....looks like good progress and you will be very happy with the results, I'm sure. I'd like to see a pic of the truck when it's in 'traction' with that whole R&R going on.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-14-2009, 10:06 PM | #4 |
Sounds like a good plan. I am anxious to see the finished project. I'm sure ya are aware thet POR-15 is some nasty stuff if not properly ventilated. It does the trick though!
1963 Chevrolet C-10 "Ginger" 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
08-16-2009, 11:54 AM | #5 | ||
I do this for many reasons:
Did you prep all the surfaces with POR-15's "Metal Ready" before applying the paint? Did you spray it on or did you brush it on?
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com Last edited by Hilandr451; 08-16-2009 at 11:54 AM. |
08-16-2009, 02:49 PM | #6 |
Good deal, I didn't mean to say you weren't competent, I just have heard some really bad stull, like livers shutting down ect. from lack of proper use. I know it works wonders in the area of preservation.
08-16-2009, 05:15 PM | #7 |
Senior Enthusiast
No, I didn't find out about Metal Ready until years after I finished my chassis. Like you I brush painted mine after wire brushing everything to bare metal. I also didn't want to render it aerosol due to health risks. It might have held up better had I used Metal Ready first.
I wish more hobbyists considered the safety aspects of the current paint products. POR is no more deadly than anything else with isocynates in it, but that's the component that can kill you. I've known lots of guys that have sprayed catalyzed paint with nothing more than a respirator (including myself when I was younger), but the iso's can be absorbed through your skin and eyeballs so you really need breathing gear for spraying. That's why I painted my truck in lacquer years ago. About 6 months after I was done the breathing gear dropped in price from $2000 to about $500, and I was disappointed I hadn't waited so I could have used better paint. Even if using old Alkyd enamel which is reasonably safe, if hardener is added that has isocynates in it. This is the main reason I'm painting my truck Blitz Black (air dryed enamel). I'm too old to give up any more lung capacity and this is my last paint job so I don't want to invest in breathing equipment that will only get used once. |
07-19-2011, 05:06 PM | #8 |
Hilander you are the reason I tore into my truck, I read your thread and said well I can do that, it only took you 3 days and I am now on 10 months, but we are close to completely frame off---ing my 66 1/2 ton gmc. Thanks for the inspiration. Kieth
It started out looking like this: http://kieth.smugmug.com/Trucks/66-G...67555158_RNLWE Got stripped down to this: http://kieth.smugmug.com/Trucks/66-G...38809030_eUypo Put back together starting here, using a 91 burb 2wd chasis: http://kieth.smugmug.com/Trucks/66-G...05_PwoKs-X2-LB And right now it looks like this: http://kieth.smugmug.com/Trucks/66-G...847715_ctDzSfp All due to your inspiration-------thanks, what am I saying should I thank you for all this pain, loss of play time, money, busted knuckles ? Maybe I take that all back----------------ha ha thanks again, Kieth It should be running in a couple of weeks..... |
07-23-2011, 05:34 PM | #9 |
well, you're welcome I guess...
Johnny and I were trying to give a good "how-to" documentation of the front end swap. Given the response this thread has received over the years, I think we were successful. Keep in mind my brother that my 66 is no where near the state of completion yours is! Nice truck!!! In fact it's pretty much in the same state it was at the end of the front end swap! Now I have to move to Bakersfield and the restoration is once again put on hold. BUT..... I will have the means to finish it when I get settled in at Bakersfield since I will be making a lot more money, and spending a LOT less on rent, utilities, groceries, commuting, etc.. also there are many more resources for parts and donor trucks where I'm going than where I live now. I must say though, that I will miss my good friend and truck partner John terribly when I go. We have had a lot of good times together working on our trucks and trolling through junk yards.
11-04-2012, 12:14 AM | #10 |
you guys did a great job with the pictures and documentation, i am just about to do the same but on my 64 1 ton.
you know when you said how its funny how life deals you the cards, like you comming back from that med. issue, and now you just dont want to stop moving, i hear you , after i lost around 225lbs i just hate sitting around. i know this is an older post but hope all is good with you. Henry.
1964 1 Ton flatbed service truck (sold) 1964 C-10 panel (project complete frame up build) 1957 210 post pearl orange |
08-14-2009, 09:25 PM | #11 |
HOW long until spring??
You have done a nice job of cleaning up the front crossmember. Amazing how a garage accumulates stuff, isn't it! Looking good!!!
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
08-14-2009, 10:50 PM | #12 |
Senior Enthusiast
It's amazing how a minor thing like a near fatal event can change your priorities, and stall your progress. I've got back and knee problems and it's taken me several weeks to get half done sanding my truck for new paint, but I'm greatful I can still do it at all.
It's good to see you're again capable of moving forward. What you've done so far looks great. For what it's worth, I also did the front suspension swap with the engine in the truck. To suspend the engine, I bolted a couple of chunks of frame rail from the donor truck, to the 1955 engine mount holes at the front of the block, and rested the other end on top of my frame. It was simple and didn't require an engine hoist to be in the way. Also, on the POR-15, you may want to check out the following link, and the testing link within that thread that shows a salt water test comparison: http://autobodystore.com/forum/showt...ht=por-15+rust We painted my entire chassis and suspension with POR-15 about 10 years ago, and I must admit I'm disppointed with how it's held up. When I wash the crud off there are quite a few rust pits popping through. I found out about Zero Rust after I had completed the chassis, but I've been using it on everything since and I think it holds up better. My truck did see 9 years of Idaho winters and gravel roads so maybe nothing would have held up. Just something to consider. |
08-15-2009, 10:56 PM | #13 |
Thanks for the tips I was thinking of doing something like that to support the engine. I bought a whole boat load of POR-15 back when I purchased all my parts so I'm committed now. besides, the back sides of all my body panels are already coated.
08-16-2009, 12:23 AM | #14 |
that is one sexy cross-member
CHEVY ONLY |
09-14-2009, 12:00 PM | #15 |
Senior Enthusiast
Wouldn't it be nice if they went back together as easy as they came apart?!
Not sure how well the power linkage system worked, but having the integral power box changed mine from miserable to nimble. |
09-14-2009, 09:49 PM | #16 |
That's what I'm counting on!! I don't know what the "power assisted" steering felt like either - it's been disconnected since I bought it 15 years ago. I hooked it up once when I repaired the p/s engine bracket, but all the hoses leaked like a red fountain. At the time, it was too hard to find hoses for so I just never got it going again.
09-14-2009, 10:39 PM | #17 |
Day two: Partial frame-off
My buddy John came by today and we kicked some tail! This is what we started with at about 11:00 this morning (John needed his beauty rest) While I was waiting for him, I hooked up the battery and just drove it in under it's own power (easier on the back) Jacked 'er up, yanked the tires. those drums are almost new - shame! Dropped the sway bar & the steering box. Plucked the brake booster & master cyl. Then we popped the motor mounts free, attached a chain to the front of the motor. Then we shoved a 2x4 under the front pulley to support the engine - worked like a charm! We dropped the old cross-member out and the frame was bare finally! Really dirty, but free of parts.
09-14-2009, 10:00 PM | #18 |
Right on!
Nice progress!!!
CHEVY ONLY |
09-14-2009, 10:40 PM | #19 |
Day Two Continued:
Removing the dirt was easy - I just transferred all of it to my body! My wife tells me I'm a dirt magnet & I guess this is proof! Shazam! The dirt just flew off! I sprayed degreaser on the frame, scrubbed it down with a scrubby, then I washed it all down with the garden hose. Then a thorough wash-down with brake cleaner then I let it dry. Now that's a clean frame! Next came the Metal Ready treatment from POR-15. I sprayed it on liberally from a spray bottle and let is stand for about 20 minutes. Then I hosed it all off again and blew it dry. The white residue is zinc phosphate an excellent rust inhibitor and etching compound for the paint. This is what you want your metal to look like before you apply POR-15 I used a propane torch to heat up areas where water would be trapped. All water needs to be removed before the paint goes on. because of it's self leveling characteristics, you need to apply thin coats. This is how much coverage I got out of a single dip of the brush. I pour the paint into a little custard dish so I won't contaminate the can. There! Done for the day! The finish is so smooth it looks like it was powder coated. After I was done, I wet the shop floor down to speed up the curing time. POR-15 cures by pulling moisture out of the air, so the more humid conditions are, the quicker the drying time.
09-14-2009, 10:50 PM | #20 |
1961 crewcab
looks great so far, I will be doing a swap like this in the future, so I am curious to see how this turns out.
09-14-2009, 11:00 PM | #21 |
Very nice pics and commentary!!!
CHEVY ONLY |
09-14-2009, 11:32 PM | #22 |
We should have most of it done tomorrow. And I didn't need my beauty sleep. Trying to get a 7 y/o ready for school is hard enough. I hope to have him out of the houst by 8 tomorrow so I can get up there at 9. Make sure you eat breakfast because I am not going out for any. We need to Git er Done.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-15-2009, 10:45 AM | #23 |
begining of day 3:
I've had me oats laddie & I'm waitin' on yoo! Oh & just so you know, you do need your beauty sleep.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com Last edited by Hilandr451; 09-15-2009 at 11:08 AM. |
09-15-2009, 10:48 AM | #24 |
Looks like 9:30 for me. Arival time that is not departure.
09-15-2009, 10:41 PM | #25 |
Day three - Re-construction: "Let the Games Begin!"
John & I started the day off making a list of what we wanted to accomplish today, and then another list of what we needed to buy to make that happen. Today's objective was to get the crossmember installed, engine bolted in, steering box & brake booster installed. We tooled down to the hardware store & dropped a cool benjamin on some new shiny zinc coated grade 8 bolts, nuts, washers and some shop supplies. Then we headed back to the shop to dig in..... The "new" cross member goes up for the first dry fit! The six 1/2" bolts on the bottom fit perfectly and so did 2 of the 4 on top. All together 4 out of 14 had to be drilled. This bolt on each side needed to be "augered" out a bit... And this one needed a new hole to be drilled. New hole drilled.... This one elongated just a smidge.
