Old 08-14-2009, 10:59 AM   #1
l79m20
Question Tech Help
My PG was making some racket as I shift tranny into gear, put it on my lift and pulled inspection cover off flywheel and 3 nuts and bolts came tumbling out all chewed up. When I replace them this weekend I need to know how much torque to apply to bolts so they stay put. These bolts and nuts mount the converter to the fly wheel. Anyone know the answer.......................Thanks.....Kirby
l79m20 is offline   Reply With Quote
Old 08-14-2009, 11:03 AM   #2
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Tech Help
i just tightened the crap out of mine
if they're not lock nuts then put some lock-tite on them
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 08-14-2009, 11:07 AM   #3
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: Tech Help
Yeah - me too. The manual says something like 35 foot pounds, but I put some of the red stuff on them and using two ratchet box end wrenches - put up as much strain as I could without rounding the Grade 8 fasteners off.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-14-2009, 11:38 AM   #4
padresag
Re: Tech Help
check the flexplate for cracks also around the bolt holes
ron
padresag is offline   Reply With Quote
Old 08-14-2009, 12:12 PM   #5
jason65
Registerd User
jason65's Avatar
Re: Tech Help
This is one time I'll agree with Ron. If your bolts are chewd up then something else is to. If the flexplate is cracked it can start popping witch can sound kinda like a motor knock.
jason65 is offline   Reply With Quote
Old 08-14-2009, 01:04 PM   #6
l79m20
Re: Tech Help
Many thanks to all that responded I'll give it a good inspection before proceeding. Great advice as always.........Kirby
Old 08-15-2009, 04:01 PM   #7
l79m20
Unhappy Re: Tech Help
Ron maybe you can help me the torque converter seems to be about 1/2 in away from flex plate and when I attempt to bolt the two together the bolts are not long enough to connect to the nuts. Is the converter supposed to move forward to meet the flywheel? and if so how does one get it to move? Does it matter which ears go to what hole?.........Kirby
Old 08-15-2009, 06:43 PM   #8
padresag
Re: Tech Help
if you lift the convertor up a bit and push it towards the flywheel it should go together. the is a pilot stub on the front of the convertor that should slip into the crankshaft to centre it. it doesn't matter where the bolts line up
ron
