Old 01-11-2003, 07:56 PM   #1
Raven Lunatic
On the Hillbilly Highway
New, lookin for thoughts
I'm on the '67-72 board, but new here... thinkin about stickin the 350 outta the '67 into the '86 S-10, but imagine it'll be a big job... it's got a 2.8L in it now, with a 4 spd o/d... what kinda things do I have to think about before I get started?
In terms of...
Trans change?
Makin room in the engine compartment?
bigger rad?
and what about going from throttle body FI to standard carb? Lotsa changes?
Any and all thoughts greatly appreciated!
Raven Lunatic is offline   Reply With Quote
Old 01-11-2003, 08:01 PM   #2
low 84
low 84's Avatar
check out this post http://67-72chevytrucks.com/vboard/s...threadid=35469
there are a couple of company's mentioned in it that make manuels that tell exactly how to do the swap. it is such a common conversion that all the parts are made like motor mounts to get it to bolt right in. it shoudln't be any problem at all. you will need a new tranny though
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-13-2003, 10:19 AM   #3
BigRed
Also, Summit sells parts specifically for the swap. Guess they're getting easier to get these days! They definitely didn't use to be!
Scott Shelbourne
BigRed is offline   Reply With Quote
