08-22-2009, 09:02 AM | #1 |
what transmission
Im new to the forum and new to these types of trucks wen my grandfather had the truck ha dskrewed up the transmission he had it in reverse nd pulled it with his farm tractor(i kno stupid) every gear works now except reverese. and my friend whos a mechanic said its not worth having the transmission rebuilt nd he said buy one. i dont kno what transsmission these trucks had can some body help me out nd tell me what transmission came in the 82 c-10 with a 5.0 motor
82 c-10 project 305 motor with 64,000 miles was my grandpas truck. needs new bed and doors and a rebuilt trannsmission. soon to have 3in cowl hood, 2inch drop, crager ss rims on low profile tires and new paint Last edited by 82lowrider; 08-22-2009 at 09:02 AM. |
08-22-2009, 06:01 PM | #3 |
Re: what transmission
82 c-10 project 305 motor with 64,000 miles was my grandpas truck. needs new bed and doors and a rebuilt trannsmission. soon to have 3in cowl hood, 2inch drop, crager ss rims on low profile tires and new paint |
08-22-2009, 06:36 PM | #4 |
Yes auto.
08-22-2009, 07:09 PM | #5 |
huh ???
Being an 82 it's more than likely a th350C...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
08-22-2009, 07:54 PM | #7 |
huh ???
It means a turbo 350 with a lock up converter. GM's first try at a turbo trans overdrive...
Chuck
08-22-2009, 10:32 PM | #9 |
huh ???
The trans will have this electrical plug on the drivers side.
08-22-2009, 10:41 PM | #10 |
Badass
yep got that.
but u said it was GM's first try at a turbo trans overdrive..?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
08-22-2009, 10:49 PM | #11 |
huh ???
I don't remember much, my buddy that has been a trans tech for years was telling us about them...
08-22-2009, 10:59 PM | #12 |
I have a 350C in my 80 short bed...it has a 4 connector plug in it though (later model).
It will not hurt the transmission to run it with out the lock up converter hooked up... I did manage to get mine hooked up recently though. search the faq section for 350C, there is lots of info about hooking them up. from the factory there was a vacuum switch mounted on the fire-wall above and behind the brake booster that would disengage the converter when the gas pedal is mashed and the vacuum drops, and an extra set of contacts on the brake light switch that disengages the converter when you apply the brakes.
CHEVY ONLY |
08-23-2009, 09:41 AM | #13 |
NOT an overdrive.
350C is a turbo 350 with a lock up converter. Basically at highway speeds the converter slips a little bit. By putting in a small hydraulic clutch the slip can be eliminated generating 3-5% less heat and improving gas mileage a little. If it is a 350C than a regular 350 will bolt in place, just won't have a spot for the wire. 350's are cheap and cheap to rebuild too.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
08-23-2009, 12:32 PM | #15 |
RPM will drop by 200-300 when cruising when it is locked
08-23-2009, 12:35 PM | #16 |
drive at a moderate to low throttle, it will go first to second shift, then second to third then shortly after the shift to third you will feel another small "shift" as the converter locks...it is easy to miss unless you are at idle or just off idle.
CHEVY ONLY Last edited by joe231; 08-23-2009 at 12:38 PM. |
08-23-2009, 12:52 PM | #17 |
Yo! I have a rebuild manual for the TH350/TH350C if ya need pics. The TH350 is a good tranny and was used extensively,...my '76 Camaro and my old '73 4x4 flatbed came with one as did most std-duty auto Chevys of the period.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
08-24-2009, 08:15 AM | #18 |
Thanks 4 the help
