Old 08-22-2009, 01:34 PM   #1
64GMCHorsepower
Justified!
drop spindle question quic
Will drop spindles for 73-87 fit my 72 front end
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 08-22-2009, 05:19 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: drop spindle question quic
Yes, but you may need to change balljoints and I'm not sure about the tie-rod ends. The calipers may be different for the early years, also....I'm not familar with the 71-72 stuff.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-22-2009, 05:39 PM   #3
SCOTI
SCOTI's Avatar
Yes, they'll swap.
The upper BJ's are the same for sure... I can't remember if there's a difference on the lowers but if there is, you simply use the 73-up lower on the 72 a-arm. You should be able to also use the 72 drag-link w/the 72 inner & 73-up out tie-rod combo.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-22-2009, 06:36 PM   #4
64GMCHorsepower
Justified!
They had some 3" drop spindles at the car show, but by the time I got back around they were gone...100.00 seemed like a good deal....
Chad
Old 08-22-2009, 07:16 PM   #5
SCOTI
SCOTI's Avatar
A c-note for 3" spindles is (was) a good deal.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
