Old 08-25-2009, 07:18 PM   #1
dnd1978
dnd1978's Avatar
Rack & pinion upgrade for my 72 c10
Could anyone help me with a rack & pinion upgrade for my 72 chevy c10 with a stock cross member. Is there a upgrade kit i can use? How about a list of parts that will work?
Thanks for the help!
dnd1978 is offline   Reply With Quote
Old 08-25-2009, 07:42 PM   #2
cdowns
cdowns's Avatar
Re: Rack & pinion upgrade for my 72 c10
only ones i've seen are with custom crossmembers and suspensiuon // i hope you've got extensive fabrication and engineering skills to tackle this job
Old 08-25-2009, 08:36 PM   #3
neonlarry
neonlarry's Avatar
IIRC a Thunderbird rack is what a lot of people use. But like cdowns said I hope you have good fab skills.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-25-2009, 11:11 PM   #4
BarryB
BarryB's Avatar
Yes It's definitely a task to install on a stock crossmember. I'm going to attempt it on mine. Once I start I'll need to finish it off. I have a power rack from a Mustang I used to own Long time ago. I bought it new in 95 and never put it on the car.
There are a couple of guys on here that has already done this swap. You might do a search to see what comes up. I know for a fact someone in the 55-?? forum did it, he used a front crossmember from a 67-72 truck and installed R/P steering on it. He was nice enough that he sent a cd with all the pics and details from his project to me. I've still got it here somewhere.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 08-25-2009, 11:52 PM   #5
woodwright
Enjoying left field
woodwright's Avatar
Check out a center steer unit. This ones out of a Dodge intrepid. I think about a 94.
[IMG][/IMG]
The center steers move more than a mustang II, and you can make your inner pivot points be wherever you want to eliminate bump steer. The bar behind the rack is just temporary so I can move it around. Just do your research cause some of the center steers are a rear steer setup so they're backwords.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 08-26-2009, 06:43 PM   #6
dnd1978
dnd1978's Avatar
thanks.
Barry B could you send me the pics? Thanks
Old 08-26-2009, 07:16 PM   #7
Boog
laying low
Boog's Avatar
I have concerns on whether or not the r&p steering units off smaller cars are strong enough for one of our sized trucks to hold up for very long, especially on those running large by wide wheels n tires and a DD too. I don't see the advantage of the r&p design over the conventional power sectors.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-26-2009, 07:53 PM   #8
mbgmike
I tend to agree. Mustang parts and other small car units belong on small cars. Remember people have killed others doing these homemade missed matched parts. I was thinking of doing it using a Sprinter R/P but still thinking about it.
I don't think r&p gets you a whole lot for the cost but one advantage is in bump steer. It get rid of alot of it
mbgmike is offline   Reply With Quote
Old 03-17-2010, 07:01 PM   #9
Fitz
My 67 stepside shortbed weighs 3100 pounds dry. a 1989-1996 Thunderbird Supercoupe weighs 3600 pounds dry. My truck will never carry anything in the bed and it will never tow anything. Since I'm a quarter ton lighter, I say
"NO PROBLEM"
Of course if you plan on putting a half ton of crap in the bed or pulling a 10 ton trailer with 10% tongue weight you better follow Boog's advice and get a different unit!
Fitz is offline   Reply With Quote
Old 08-26-2009, 07:23 PM   #10
dnd1978
dnd1978's Avatar
thanks Clint could you send more pics
Old 08-26-2009, 09:37 PM   #11
BarryB
BarryB's Avatar
Yes I can, but give me alittle while to find them. Maybe this weekend. PM me to remind me if I forget , which has been known to happen.
Two rules in life.
Old 09-20-2009, 08:16 PM   #12
CSGAS
optomistic ah-so
CSGAS's Avatar
This thread doesn't look half as old as most that get dragged up...
...that Intrepid rack looks interesting. What pump pressure (regular GM, I hope) does it seem to like?
What rack did you choose, dnd? Progress report?
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 03-17-2010, 06:09 PM   #13
truckeez
Again -Second gen dodge dakota is supposedly got the right inner knuckle spacing in relation to the upper-lower a arm pivot points.
truckeez is offline   Reply With Quote
