01-12-2003, 06:28 PM | #1 |
i love summertime
67/68 chevy front clips vs. 67/68 gmc front clips
hey guys i was wondering if you can change just the grille on a 67-68 gmc to a 67-68 chevy, or do you have to swap the whole clip? my dad is a chevy guy and is looking at a 67 gmc but likes my style grille more....can it be done?
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
01-12-2003, 06:31 PM | #2 |
I think so you would need a grill and rad cradel at most I think that it. correct me if I am wrong.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-12-2003, 06:36 PM | #3 |
i love summertime
why is the rad support different? btw i know i need the grille....
01-12-2003, 06:39 PM | #4 |
I am not sure if GMC had the head light perches on the rad cradel or not. You can aways grind the spot welds off of the light perches . Just didnt want to miss lead to into thinking that a Chevy grill is behind the GMC!!!!!!
01-12-2003, 07:31 PM | #5 |
i love summertime
hehhe np mario.....anyone else know forsure...
ttt
01-12-2003, 10:31 PM | #6 |
UHHMMM
Don't the GMC' have 4 headlights versus Chevy that only had 2 or did I have to much beer 2-day uuuhhhmmmm.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-12-2003, 10:43 PM | #7 |
i love summertime
i know they do....but is that the only diff?
01-12-2003, 10:52 PM | #8 |
yesss
YES Don't 4 get the wire harness
01-13-2003, 07:18 AM | #9 |
To swap a 67-68 Chevy grille for a 67 or 68 GMC grille you need 67/68 Grille top bar and main lower grill, forward lamp harness and the core support. If your support is good you can drill the spot welds out holding the GMC dual headlight frames on the GMC core support and weld them to yours ( Be sure to first make a pattern off GMC support so they are positioned correctly when re-installed ) or just swap supports out.
GMCPaul OOPS you wanted GMC to Chevy, Cut the extra headlight connectors off current harness, if your lucky the small square openings are in place behind the GMC dual headlight buckets on the core support so that if you remove the spot welds holding them on you can put the adusters in for Chevy headlights, you will need the 2 larger Chevy headlight buckets, and SS retainers. Now since your going From GMC to Chevy if you have no need for that 67-68 GMC top bar, the headlight bezels and main grill you should contact me. GMCPaul Last edited by GMCPaul; 01-13-2003 at 07:35 AM. |
