Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-29-2009, 02:03 PM   #1
Wild83C10
Wild83C10's Avatar
NX Gemini Twin Kit Plan NANO
For Sale is a used Nitrous Express Gemini Twin Pro Power Nitrous Kit (P/N: PN: 60540-15). Good for a 100-500 hp shot. No bottle
15 lb NX bottle and NANO sold, updated prices below:
NX kit (noids and plate): $310
HSW Bottle Bracket: $70
Opener: $110
HSW Microedge: $120
Switches/Plate and fuze box $40
I'm switching to a turbo setup, that is why I am selling.
Please ask any questions. Thanks!
Gemini Twin Info:
"The Gemini Twin plate system is the most technically advanced single stage plate ever designed. The unique direct-port pattern assures you perfect nitrous-fuel distribution. It solves problems commonly found on single plane manifolds, particularly small and big block Fords. This new innovation provides superior distribution and outstanding atomization. With no spray bars to sag, split, block airflow, or damage this is truly the Next Generation in nitrous plate technology. This Pro Power system includes jetting for 100, 200, 300, 400 & 500HP and Includes limited lifetime warranty Lightning solenoids, heavy duty 40 amp relay, stainless bottle brackets, and extra D4 long supply line (Race Hose). Fits standard 4150 flange carburetors."
Feature Set of The MicroEdge:
RPM Window Switch: Only operates the nitrous system within a set "window" of RPM.
TPS Activation Switch: Only operates the nitrous system at (WOT) wide open throttle.
Dual Stage Control: Allows for the use of multiple nitrous kits to be run off of one (1) window switch. IE; multiple stages which can be used with different RPM & TPS values.
A/F Shut Down Switch: Nitrous system(s) will shut down if a lean condition is detected by either a wideband O2 sensor or narrowband O2 sensor. The MicroEdge will also shut down the system if an overly rich A/F is detected (wideband sensor only).
Lean Out Delay: The MicroEdge controller can be programmed to not shut down the nitrous system for a determined amount of time if a lean condition is detected. Great feature for those small lean spikes upon kit activation. This feature can be adjusted up to 10 seconds in .05 second intervals.
Multi-Gear Lock-Out: Can be configured for both stages and can lock-out multiple gears to optimize traction.
Time Delays: Activation of kits can be delayed for up to 10 seconds in .05 second intervals.
Pedal Delay: Delay(s) used to re-gain traction if the system is activated and the gas pedal is let off due to wheel spin and then re-applied. This allows for momentum to be built prior to re-activating the nitrous system(s). Both stages have their own pedal delay which is adjustable up to 10 seconds in .05 second intervals.
Nitrous Solenoid Delay: Delays the nitrous solenoid from being activated for an amount of time after the kit is activated. This helps to cure any lean spike issues that are pre-existing in the system.
Display: Built in LCD display can show RPM, A/F Ratio (mV for narrowband), TPS voltage, Battery Voltage, and Arming Switch Voltage.
File System: Up to three (3) files can be saved within the MicroEdge unit for quick and easy loading between runs.
Upgradeable: Easily upgradeable to the MicroEdge+ for progressive control features. For more info follow this link: MicroEdge+
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 08-31-2009, 09:00 AM   #2
AirMale
AirMale's Avatar
Re: NX Gemini Twin Kit Plan NANO
awesome set-up. Wish I had an extra grand. ttt
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 09-17-2009, 07:15 AM   #3
Wild83C10
Wild83C10's Avatar
NANO and 15 lbs NX bottle are sold. Check out the new pricing!
turbo=
