08-29-2009, 08:15 PM | #1 |
VA72C10
Setting cab on its back okay???
I've seen it done on here but always worry about damage. The cab is currently on jack stands mounted to the tire rollers you can roll a vehicle around a shop with. Makes it easy to move around but impossible to clean and paint the underside and fix the cab mounts. Can I safely lay the cab on the concrete floor and do all my cleaning up and painting before re-mounting to the frame? Do I need to brace in the door openings? The rockers are in place already....thanks for any advice. (other than purchasing a tip and flip dolly as that's out of budget )
Looking for a 67-72 swb or blazer project in or around VA. |
08-29-2009, 08:50 PM | #2 |
Re: Setting cab on its back okay???
I would do it. I have done it. I don't see an issue.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
08-29-2009, 11:52 PM | #3 |
Formerly- 1972SuperCheyenne
I laid mine on it's back to clean the bottom. Didn't have any issues either. Just have someone help you so you dont wind up rolling the cab corners in.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-29-2009, 11:54 PM | #4 |
VA72C10
Okay, sounds good...so no one put any bracing with the doors out? I just know the firewall is real heavy.....
08-30-2009, 12:06 AM | #5 |
its all about the +6 inches
i would probably make a brace from the hinges to the latch.
I'm sure many have done it, but I have seen one that got tweaked from doing this. |
08-30-2009, 12:12 AM | #6 |
VA72C10
That's what I was worried about...I would be the one that would have it happen too...
08-31-2009, 11:05 AM | #7 |
Way back before I ever heard of a rotisserie we used to tip 20s and 30s cars over on an old mattriss to work on the bottom. LOL!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
08-31-2009, 11:11 AM | #8 | |
Keep an eye on the cardboard or other padding if you do a lot of grinding or weld on it when it is tipped over though. |
08-31-2009, 11:42 AM | #9 |
Mine was on its back for a number of weeks while we welded in new cab supports etc. Back on the truck now did not seem to do it any harm at all. The doors were off.
08-31-2009, 04:13 PM | #10 |
Do not just roll it over or you will most likely roll the lower rear part of the cab corners in where it rolls up to the floor... Pick it up, flip it and lay it down..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
