5.3 SWAP Wiring Problem
I have a 2007 Silverado 5.3 motor and engine bay wiring harness. My problem is finding the wiring diagrams that can help me eliminate the wires and were to hook everything up to get this motor running. I am starting to get frustrated with all the googleing, tying to fix this. I have the fuel system lined out. Cooling system is ready to install, I just want to get it turning over! Please help me figure out the wiring harness.
Thanks in advance, Shane |
its all about the +6 inches
Re: 5.3 SWAP Wiring Problem
shane.... what part of the board did you want to post this in?
This (burb forum) is probably the last place you'd want it. There's been a few people who have installed gen III engines in 67 - 72 trucks (I assume thats what you are working on since you never said) We need some more info, and i can move it to the right forum upon figuring out what it is you need. |
#3 | |
done.
60-66 Nut
Years ago I bought a book at NAPA that had all the engine wiring diagrams for most all vehicles. I haven't looked to see if they have a newer edition that covers the newer year vehicles. It might be worth a look. There is also a wiring conversion book on ebay. I haven't bought it, but I thought I'd mention it so you can check it out if you like.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Questionable
Need you to be more specific. Auto or manual trans?
Also, seriously...think about the time and frustration you've dumped into it already. Why not send your harness to Speartech (http://www.speartech.com/) and have them rework it for you? What you get is something (usually) better-than-home-hacked with zero effort on your part. There are cheaper ways to do it, but ... This is pretty much one of the best, albeit pricey, methods. If you really insist on doing it on your own, LS1tech is one of your best resources. http://www.ls1tech.com/forums/conver...-diagrams.html You'll need to sign up. I'm over there, my username is almost the same over there, only there's a ` at the end (shifty`)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Junior Member
I know speartech is good but they are pricey. Waitf4meperformance is cheaper for redoing the oem harness. It is not as nice looking as Speartech but it should work. I just got mine back from them. They charged $360 for rework my oem harness and tune. I do not have it installed yet to show any pics.
1967 Camaro (in pieces) 1972 Chevrolet K/5 Blazer 1969 Chevrolet K/5 Blazer 2000 Chevrolet K2500 Crew Cab 454 1999 Chevrolet Blazer 2008 Polaris Ranger XP Orange Crush ![]() |
Questionable
I used W4Me also. After seeing both the Speartech harness and the W4Me harness, all I can say is ... you get what you pay for.
The W4Me harness worked fine also, although the instructions weren't exactly provided to explain how to hookup, so I had to ask 5 million questions. The Speartech harness was so simple, plug and play, clear instructions, all relays present for fuel pump and fans, etc. I dunno. If money is no object, I would have probably go Speartech. It would've saved me several hours of cleaning up and work.
Are you just looking for the pin-out locations on the PCM? If you still need them on Tuesday, let me know and I'll send them to you. I can get them at work.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. |
Well, I sent my harness to Wait4meperforance and thy did an awesome job. I had alrady purchased fuel pump and electric fan relays. So, they pu me some drops of the harness to connect the relays to. easy and painless. It was easy to connect everything. Thanks for the information and assistance
Well, I finally had time this weekend to install the harness, AND i'm frustrated again. I have everything exactly as Wait4me explained it. and labeled it. Except for the oil level sensor, I can't find it. before you go saying it. I have looked everywhere on the passangers side of the block and oil pan and it is not on my engine. Can this bebypassed and will it start without it connected
Second, The engine will not start. NO SPARK. I have fuel (plugs are wet with fuel) and it turns over but I can not get it to spark! Checked all my grounds and they are good. For some reason the PCM is not telling the coils to fire. Any ideas? |
Who did your reporgraming?
Wait4me Performance. I'm thinking the VATS was not removed.
move this sucker to the LSx swap forums already! --
#15 |
OK, Hooked up the Crankshaft position sensor, CHECKED ALL my ground wires again, and still nothing. Got the Battery checked at the auto parts store, had to charge it from cranking it so much and still nothing. I have fuel but NO Spark. I don't get it. And to top it all off, I only have sundays to work on it. Soooo, calling Wait4me Performace on sunday is out of the question, and trying to call them on a week day and get one or two ideas then wait till sunday to work on it again sucks!!!
I'm about one second away from selling this POS project! |
#16 | |
07 is a split-year. Did this engine come from a old or new body truck? The best advice I can give is for you to calm down, The truck is worth more when its running ![]() |
#17 |
I think it's the new body style, my VIN is 2GCEK13Z071141116. If anyone could decode that and tell me I would appreaciate it. I have fuel in the cylinders, the plugs are wet. Wouldn't the injectors prevent fuel from getting in the cylinders if they were not pulsing?
#18 |
It came out of a 2007 Silverado Classic 1/2 ton 4X4 crew cab with a Flex Fuel (L59) 5.3L. (old body)
There are two grounds behind the intake by the cam sensor. Are those grounded? #2 & #4 are the grounds im talking about #3 is the camshaft position sensor |
#19 |
Yes they are both connected, I have been Coresponding with Jesse at W4M, he said to check the harness, make sure all the pink wires have 12Vdc, funny... I sent it to them to get it fixed in the first place, didn't think I would have to double check there work! If that was the case I would have done it myself.
I found Three grounds, the two in the back pf the engine, that you pointed out, and one on the front, behind the Power Steering pump. Then My Chasis, Engine, Body and Battery Ground straps. |
#20 |
Truck and auto performance nut
Would it possibly need a crank relearn procedure done for some reason?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#21 |
It might, How do you do that? I don't have a check engine light to view any codes. Any idea's how to rig one up?
#22 |
What fuse box are you using for your harness. Verify the fuse is good/ there. Verify connectors at the fuel rail are connected good. This is the connector on each side of engine that connects coil harnesses to engine harness.
#23 |
I'm using the original 72 fuse block with an inline 15 amp fuse to the harness then a 10 amp fuse to the ECM/PCM.
#24 |
#25 | |
Tags |
2007, 5.3, diagram, harness, wiring |
