Old 08-30-2009, 07:23 PM   #1
72WiscSub
72WiscSub's Avatar
heater switch
I got my new heater blower motor in and it works, but when I put the fan switch in the high position motor does not blow. The other settings work fine.
Is this a bad AC relay switch under the dash? I remember reading a past post but I can't find it.
Nice to have heat again, starting to get a bit chilly up here in Wisconsin.
Also have some good news.....I decided not to sell the Suburban. With my wife going back to school things will be really tight, but I can't get rid of her right now, it is just too nice. I just enjoy working on her to much, and the driving isn't bad either. It was nice to talk with a couple of the guys on this board about it.
No I just have to find a place to store her for the winter. Gonna be a long 6 months.
72WiscSub is offline   Reply With Quote
Old 08-30-2009, 07:30 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: heater switch
No help with the switch...but glad you'll be keeping her....Also, glad to chat with you about it!!!...Now get'er covered up before it gets snowed in!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 08-30-2009, 07:36 PM   #3
JimKshortstep4x4
Re: heater switch
There is a good chance the relay is bad or the wires going to the relay have a problem. Here is a picture of the AC unit. The relay is on the right side of the heater box and is mounted upside down.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-30-2009, 10:21 PM   #4
72WiscSub
72WiscSub's Avatar
Re: heater switch
Thanks for the pix JimKshortstep4x4. I will check out the wiring and get a new switch. Hopefully the local parts store has the switch, if not time to order online!
Hey gcburdic, it was good talking to you. If life ever brings you to Wisconsin let me know. We can go for a cruise and get some chow. Thanks for not making an offer!!!!!!
Old 08-30-2009, 10:39 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: heater switch
When mine failed to work on high, it was just the switch... and the local NAPA had one.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 08-30-2009, 10:44 PM   #6
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: heater switch
Will do!....If that thing was closer, I would of been all about taking it off your hand....of course just to help out your situation
Now get that heat fixed...it's cold!!!
Geoff with a G
Old 08-30-2009, 10:44 PM   #7
72WiscSub
72WiscSub's Avatar
Re: heater switch
Thanks Stocker, I will make a trip to NAPA tomorrow.
Old 08-30-2009, 10:44 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: heater switch
before spending any money, make sure the relay is grounded.
Old 08-31-2009, 01:09 AM   #9
Daves72'GMC
Question Re: heater switch
how do you ground the switch and where?
Daves72'GMC is offline   Reply With Quote
Old 08-31-2009, 06:30 AM   #10
Longhorn Man
Re: heater switch
the screw that holds it to the box... if memory serves, it is in a steel support or something which grounds it.
The relays also typicly rust apart there due to water since that corner of the cowl is a very common leaky spot.
Old 08-31-2009, 08:04 AM   #11
72WiscSub
72WiscSub's Avatar
Re: heater switch
I'll check the ground and see how the relay looks as far as rust.
Old 08-31-2009, 04:53 PM   #12
Longhorn Man
Re: heater switch
I'm starting to think maybe there is supposed to be a ground wire under the screw that mounts the relay maybe...
It's been almost 2 years since I messed with one... but I do know it needs to be grounded or it won't work.
Old 08-31-2009, 09:34 PM   #13
72WiscSub
72WiscSub's Avatar
Re: heater switch
Cool. I will reference the electrical schematic for wiring details.
Old 08-31-2009, 09:49 PM   #14
JimKshortstep4x4
Re: heater switch
Longhorn Man is right about the ground wire under one of the mounting screws. You check the ohm reading of the relay to ground to make sure the ground is good.
Jim
