![]() Join Date: Nov 2007
Radiator Dimensions
I sold my old radiator with the intentions of getting a drop in aluminum replacement from these guys --> link
However, looking thru my new summit racing catalog, BeCool has a new universal line with GM style inlet and outlets. Only problem is, I don't know that actual length and height measurements, since I sold mine already ![]() Thanks. |
Wide n'Low
![]() Join Date: Jan 2007
Re: Radiator Dimensions
Seems most of the aftermarket one's I see going in are 19x31. My original one was 19x33, but the replacement worked great.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired Last edited by Twisted78SS; 08-31-2009 at 02:13 PM. |
![]() Join Date: Feb 2000
My replacement 4 core measures about 33 wide by 18 tall and is about 2 1/2" thick.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Be careful with that lower water outlet neck, had a heck of a time getting alignment right, mine was strait, but yours looks like it angles up and maybe of help. Good luck to you, as always, you know the drill, post up pics
![]() Using stock four core brackets was also a challenge b/c alum. rads are squared and factory are more rounded at the seam where the brackets sit
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-31-2009 at 08:51 PM. |
I think the radiator "size" is 27", that is just the core measurment not including the "tanks". When I ordered my dual fan & shroud setup from Flex-a-lite I ordered the one for 27" GM Radiators...
My clubs site is down so I cannot post up pics ![]() ![]() ![]() ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Its Topless Season!!!!
AJ....I just saw this thread...I 'll get you the exact dimensions later on today since it's your old rad.Carlos
2WD Jimmy
![]() Join Date: Mar 2005
Now wait... did you want the measurments of the existing radiator or the BeCool? I have a 1000hp BeCool which I can measure if you want.
#8 | |
Wanted the dimensions of the old rad to use as a starting point for the new one. |
AJ ..the rad measures 34Lx19Hx 3 1/4 where the brackets mount...hope this helps
Thanks Carlos.
