any good header paint out there?
I haven,t painted any headers in awhile,is any of that new stuff like vht with ceramic work well.The stuff that comes on the headers doesn,t last long.
86 C10
Re: any good header paint out there?
i dont know, but i know that that duplicolor stuff sucks it burned off like in a week or two
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
It'd be alot cooler if you did
I've never seen any "spray bomb" paint that worked on headers that lasted longer than a few days.
The old VHT stuff works well ( I think it is now Mr Gasket or whatever Summit calls it now) BUT you HAVE to follow the directions to a T, the whole deal- sandblast, wipe clean w solvent -DO NOT TOUCH it w your bare hands!, Use plastic gloves. The oil in your skin will mess up the whole thing. Then cure per directions on the can. I used to have the same troubles until I actually did the whole routine including the warm up curing steps. I have a set painted white on a BBC car and they look great after 6 years w some yellowing around the ports is all.
#5 | |
a fool with no money
YOU MUST FOLLOW THE DIRECTIONS EXACTLY! from prep to cure... it's easier if you have an electric oven that they will fit in
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
crazy idea just popped in my head how about the black paint wood stove since it's made for wood stoves it should be heat resistant, but aren't most stoves cast iron...just a crazy idea to throw out there.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
Eastwood makes A good product called high temp coating .You brush it on run it for about twenty min. bakes it on. did my headers two years ago still look good
John Deere muffler paint.
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
I,ve also heard of rubbing tranny fluid on headers,burns the header black I,m told but haven,t found anyone who,s done it
#11 | |
