Old 09-03-2009, 10:31 AM   #1
1968aj
speedo stuck
my speedometer sticks at 30 mph. it will go up to 30and just hangs there. when i park the truck it remains stuckon 30. i can tap on the back of speedo while parked and it will drop back down but the next time i drive it the same thing happens.the truck is a 1968 cst.i have tried to post pictures but it will not work. i have posted other pictures in truckes for sale but it will not work here any help is appreciated
1968aj is offline   Reply With Quote
Old 09-03-2009, 10:49 AM   #2
cdowns
cdowns's Avatar
Re: speedo stuck
step one//take out and clean and lubricate the speedo cable with speedometer cable lube NOT WHITE GREASE
Old 09-03-2009, 10:49 AM   #3
tim21391
tim21391's Avatar
Re: speedo stuck
id get a new speedo cable they are cheap.. maybe the speedo itself is bad? or maybe the thing on the tranny is broke
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 09-03-2009, 12:03 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: speedo stuck
Wouldn't hurt to lube the cable but the cable just turns a magnet that produces a magnetic field that move the needle. Eddie currents.
More than likely you have a bad speedometer. Maybe taking it out, checking the connections, making sure the needle is not loose, etc. may help, but I would start looking for another one.
68gmsee is offline   Reply With Quote
Old 09-03-2009, 01:01 PM   #5
69GMCLonghorn
69GMCLonghorn's Avatar
Re: speedo stuck
I agree... Also think of it this way, it's probably about to fly south on you altogether. So learn something in the process. Get in there and break something and learn what's happening and how it works. You might scare yourself and actually fix it! And, if you screw it up, throw it in da guttah and go buy anuddah!
69GMCLonghorn is offline   Reply With Quote
Old 09-03-2009, 03:11 PM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: speedo stuck
I agree. I really don't think it's the cable. Your needle is probably hanging up on the dial face. You need to disassemble the speedo and realign the needle. If that doesn't fix it, it's new speedo time.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-03-2009, 02:56 PM   #7
1968aj
Re: speedo stuck
thank for the input. i took the instrument cluster out and cleaned it &painted it. iput led bulbs in.when i reinstalledit is when this problem came up, itwas working brfore i took it out.
Old 09-03-2009, 03:01 PM   #8
1968aj
Re: speedo stuck
i just read my post. i can spell good but cant type worth a ......
Old 09-03-2009, 04:19 PM   #9
1968aj
Re: speedo stuck
ok i think i will take it back out . i have a 72 parts truck. does anbody if the 72 speedo is the same as the 68?
Old 09-03-2009, 04:29 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Re: speedo stuck
Should all be the same. I think I took the one for my 69 out of a 72 GMC.
You'll probably see if there's any differences when you take them out and compare.
Old 09-03-2009, 04:30 PM   #11
john
member #16
john's Avatar
Re: speedo stuck
Did you pack the cable with grease? I over lubed a cable once and the grease got into the speedo head and acted the same way. Yes the 1968 unit will work.
john is offline   Reply With Quote
Old 09-04-2009, 12:07 AM   #12
unclewatts
unclewatts's Avatar
Re: speedo stuck
According to my catalogs they all list the same replacement speedo for years 1967-72 and they're about $75.00.
