1966 Clutch question
What clutch setup are you guys running. I have a saginaw 4 speed and I have to change out the clutch linkage.. Look at the pics and you will see why.
![]() Here's the setup... ![]() Here you can see that the pivot is bent to hell and back.. I'm pretty sure its not supposed to be like that. I think the PO had to bend it to match up to his homemade bracket. It needs to be replaced but I don't know where to find this part, or any aftermarket setups. Any suggestions? |
Re: 1966 Clutch question
actually i think it is pretty funny shaped from the factory, yours looks almost exactly like my old one.
Jason Garverick 64 C10 SWB Stepside 350/muncie - 5.3 vortec (soon)Thread 69 AMC Javelin 360/auto - 417 stroker (soon) 68 Scout (Basketcase) 06 Ram HEMI SWB Reg Cab Daily Driver US Army Vet |
Really???
I would think it would be straight. It works, I was just afraid I would be driving and it would fall apart.. Now that you mention it, I doesn't look like he heated it up and beat out of shape. Oh well.. I'll just replace the stripped out allthread piece Thanks for the reply.. One less thing to worry about.. ![]() |
![]() Join Date: Sep 2006
My clutch has a bracket that bolts to the top of the frame and the other end goes into the bellhousing, I think it is the same for I6 or V8 engines. If your bellhousing is different, like not for a truck SM465 then you may have to fab one up that bolts to the bellhousing somewhere. Or you could go to a hydraulic set up but thats alot of work.
![]() Join Date: Nov 2007
Rhoff,
The clutch pivot arm is definitely supposed to be that shape. I just took the one off my 65 and since my dad or I have had the truck since it was new, I know it was not modified. The frame side bracket is rivitted to the frame rail and has a slot to accept the ball on that end. I suppose your truck was converted from an auto? TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
60-66 Nut
Yes that bellcrank is just as GM made it. Where was that other bracket located? It is not a factory piece that I can tell. You will definitely need a new swivel on the rod. It is almost worn thru. What engine is in your truck?
You can use all the factory clutch linkage whether you have the SM420 or the saginaw 4 speed.
Here is a pic of the same arm, just for reinforcement that yours is ok, and I did mean SM420, got mixed up with the saginaw 465TT I was selling.
#8 | |
![]() Here's a pic of how it sits in the truck.. If you can see it in my earlier post the PO made a bracket and welded the pivot ball to it, relocating it about an inch foward. I guess it was because it broke or got stripped out or something. Thanks tx firefighter for the links. I'm guessing the threaded hole by the dipstick is where the pivot ball actually goes. That was the reason I was worried about it, since he made that bracket I figured he bent the linkage to make it fit. But now I know. Thanks alot guys.. |
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I ordered everything I needed to restore my clutch linkage from Classic Parts. Most all of it was genuine GM stuff when it arrived. Not much money at all. You need one of these because yours is very worn: ![]() http://www.classicparts.com/1963-72-...ctinfo/90-827/ One of these to screw into the engine block: ![]() http://www.classicparts.com/1963-84-...ctinfo/90-844/ One of these springs: ![]() http://www.classicparts.com/1963-72-...ctinfo/90-791/ One of these for the end of the rod where it fits into the clutch fork: ![]() http://www.classicparts.com/60-72Low...ctinfo/90-829/ Since your little pivot block on the pushrod is so worn, your holes in the Z bar are likely worn too. Either weld them shut and redrill new holes or fess up the 40 bucks for a new Z bar: ![]() http://www.classicparts.com/63-66-Cl...ctinfo/90-805/ Done deal !
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 09-05-2009 at 08:12 AM. |
Eagar1,
![]() Here is a normal bellhousing. There isn't even a place to screw a stud in to. Plus, if you did, the z bar would be way up under the cab with no way of working from the pedal. I can't remember too many details about the later model bellhousings like you have though. I have an 80 model bellhousing hanging on the wall in my shop. It's aluminum. I will look at it next time I go out there.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 09-05-2009 at 02:54 PM. |
Didn't mean to hijack the thread, but yes the 81 housing is aluminum, but I do have the 72 bellhousing also that the 72 tranny is still attached to, they look the same, as they are toploaders, so I assume I can bolt that 72bellhousing to the 81 engine, and my 81 4-speed to that. The 81 bellhousing doesn't have the lower mount pads like the 72 one does.
#12 | ||
60-66 Nut
Yes right there by the dipstick is where the ballstud goes for the bellcrank to pivot on. Get the parts you need from the links TxFirefighter provided and you'll be in business. Also, the arms on the bellcrank are hardened and don't typically wear, but I have seen some slightly worn. It is usually the other parts that wear.
I believe that the '81 4 speed you have would be the SM465 which should have a 5 1/8" dia front bearing retainer where it fits into the bellhousing. You might want to check your '72 bellhousing to be sure that the bore of it is the correct size. The older bellhousings which were for the SM420's had a smaller bore to fit the front bearing retainer on them. I don't remember the size for sure, but I think it was about 4 3/4". Yes you can bolt any small or big block bellhousing to your '81 305. Quote:
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-06-2009 at 12:35 AM. |
Thanks Captainfab,
I still have the old v8, bellhousing and trans all bolted together, but it has been out in the weather for a while, and I am not sure the trans isnt full of water. thats why I wanted to use the newer trans, it was taken from a working vehicle and kept inside, but if the SM420 is better than the SM465, I wouldn't be opposed to going through it and making that work instead. |
#14 | ||
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 09-06-2009 at 12:01 PM. |
#15 |
You should be able to use whichever bellhousing you choose. The center bores of the two should be the same.
#16 |
Hey tx.. I checked out your blog, very nice looking engine.
Off topic, but do you know which power steering pump brackets are used for that pump, I have the same one but I don't have the short water pump like you have. It seems that everywhere I look they only have the brackets for the later model pump. |
