Old 09-06-2009, 01:19 AM   #1
slepysal
slepysal's Avatar
high beam problem
On a 60 stepside, the headlights work, buy when you push the high beam switch,both lights go out. I ran a direct lead to the head lights both low beams work, but only the right high beam worked.I swaped out the dimmer switch but same thing.
Any ideas ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 09-06-2009, 01:43 AM   #2
MXmaniac
MXmaniac's Avatar
Re: high beam problem
Is your dimmer switch getting a good ground? Mine used to kill both lights when I switched on the high beams until I removed the switch, and cleaned up the surfaces to make a good ground. Then they worked perfectly.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 09-06-2009, 07:49 AM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
Normally dimmer switch
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-06-2009, 10:30 AM   #4
damnyankee36
damnyankee36's Avatar
Dimmer switches aren't grounded. They're just a simple SPDT switch.
The only thing left to inspect would be the connectors/terminals in the circuit. You can use a test light to probe the wires coming out of the dimmer switch to see if you have power in both the dim and high beam positions. Then, work your way towards the headlights.
On the 66, the light green wire is the high beam and the tan wire is the low beam. The light blue wire comes from the headlight switch. The 60 might be the same.
The terminals at the dimmer switch are notorious for burned and corroded connections. I'm willing to bet the problem is there.
damnyankee36 is offline   Reply With Quote
Old 09-06-2009, 05:39 PM   #5
MXmaniac
MXmaniac's Avatar
I did this on my '69 a long time ago, maybe its a different set-up. I just assumed it was the same.
Andrew
Old 09-07-2009, 01:24 AM   #6
Captainfab
60-66 Nut
I've had this same problem before Sal, and this was the cause.
Old 09-07-2009, 01:46 AM   #7
slepysal
slepysal's Avatar
Thans to all I will check it out Tuesday. The truck is at work and I have been working on it at lunch, I think thats what I'll call it "lunch truck "
I will let you all know what gives thnks again
