Old 01-13-2003, 05:57 PM   #1
starsky1231
Low Compression - 87 305
I have a 1987 Chevy C10 w/ a 305. Compression in cylinder 6 is well below the others. Any possible options rather then pulling it and resleeving the chamber. Thanks.
starsky1231 is offline   Reply With Quote
Old 01-13-2003, 07:56 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I would pull it, and replace it with a 350.
Seriously, you don't resleeve it. It sounds as though it has quite a few miles, so it's probably ready for a rebuild. But, it's possible other things could be causing it, such as maybe valves. My vote would be rings are worn.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-13-2003, 08:03 PM   #3
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
Have a shop do a leakdown test. If the air is coming from the dipstic tube, then try new rings. If it comes from the carbuetor or muffler, then do valves. But as Mike says, a rebuild might not be a bad idea.
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 01-14-2003, 12:12 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
First Welcome to the board.
How did you do the compression check? Was the engine hot or cold? Did you crank at least three times to build up pressure? How many miles on the engine? A little more info would be helpful. Sounds like you're familiar with mechanics.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
