09-08-2009, 09:02 AM | #1 |
One of the First
Help: Looking for: Tank Filler Neck
I have to replace my fuel tank on the Blazer. No help for it... I'm going to replace with a steel replacement but the filler tube has to be exchanged from the old to the new. Mine is rusted around the end and if I trim the bad spot out (shorten) it will be right on the bend. Yeah it will probably leak. I know that this will be a hard find, as no on likes cutting up gas tanks. But hey... gotta try!
Thanks, David
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
09-08-2009, 10:01 AM | #2 |
Re: Help: Looking for: Tank Filler Neck
Will JBWeld hold up under gas? Since ya gotta cut it off, you could braze or solder it
09-08-2009, 10:09 AM | #3 |
One of the First
I can make it work, one way or another. I'm just particular about repairs like this. I would like to just install a good filler neck on the repacement tank. Thanks for the suggestion though...
09-08-2009, 12:34 PM | #4 |
Any muffler shops with a mandrel bender in Fla.?
09-08-2009, 12:39 PM | #5 |
I have a tank I'm not going to use, but I don't think the fill tube is that long. I will check though. If it is, I'll hack it off for you.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
09-08-2009, 01:22 PM | #6 |
One of the First
Jimmy, If its the original tank it will look exactly like the one in the picture. If you would, could you cut the tank and not the filler tube (pictured). I will desolder and solder in the new tank. In the picture, the partial rubber hose is still attached to end. Thanks
09-08-2009, 06:51 PM | #7 |
I sent that exact same patch out to someone a few years back, it happens.
09-08-2009, 10:44 PM | #8 |
Huh, well what do you know? Make me an offer, and what is your time frame? I also need to make sure that the suburban tank I have won't need this, but I am pretty sure it won't.
09-09-2009, 06:38 AM | #9 |
One of the First
Jimmy, I think sub tanks are a little different, But thanks, PM'd you. DP
09-09-2009, 09:24 PM | #10 |
Why not just cut it back and run a longer hose? Or am I missing something?
Edit: Oh, I should read closer... I' think it will be fine on the bend. Make up for not having the ridge to hold the hose anymore.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 09-09-2009 at 09:25 PM. |
09-14-2009, 05:36 PM | #11 |
D.Passmore - PM me if you're stuck. I got an old tank out back, but it's a long way from your part of the woods. The neck is about the only good thing left on it.
09-14-2009, 06:04 PM | #12 |
One of the First
Will Do, Thank you.
09-14-2009, 11:31 PM | #13 |
I've got one going to the trash can but I think the filler is good. PM me if nothing works out for you.
