![]() Join Date: Apr 2005
Parting 1968 Big Block SWB truck
Matching 402/TH400 + lots of MISC...$600!!!
71 402 motor/TH400 tranny, matching set - $600 (pick up only) Code Year Model CID HP Trans Comment TKB 1971 Truck 402 310 400 L-47 10, 20, 30 motor stands and mounts - Sold distributor (new points/coil) - $30 oil gauge line (outer) - $20 tranny auto crossmember - Sold heat shield for passenger's fire wall - $25 exhaust manifolds (perfect no cracks) - $100 air cleaner and spacer - $40 4 core radiator - $75 Dual flowmaster (40 series) setup with H-Pipe - $125 (pickup only) 1968 bench seat, great foam and cover - SOLD 1968 auto column - SOLD ** Pulleys and brackets sold to camtoys1 ** Complete p/s setup (pump (no dents), reservoir, pulley) - $225 a/c 9-bracket setup - $275 alt brackets - $125 all 3 pulleys - $100 fan shroud, clutch fan and shift linkage ** SOLD to BB72CHEVTK ** Perfect heat tube (breather to exhaust) - ** SOLD to Sameyrasmea72 ** exhaust heat shield - ** SOLD to Dantip ** 67 SWB - ** Sold, thanks Tom! ** tailgate - ** Sold, thanks Tom! ** The cab, front clip and chassis have been sold. All prices are + shipping (paypallers add 3% for fees)
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-15-2009 at 12:32 PM. |
Restoration Virgin!
Re: Parting 1968 Big Block SWB truck
OH NO!!!....Bye Bye 50th clone!!!....Sorry to see it go this way
![]() TTT for ya Rob!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
"the other guy"
side view mirrors with backing plates shipped to 95901?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
What Kind of shape is the tailgate in and would you ship to 39402 might be interested in the rad as well?
1986 GMC 4x4 |
#5 | |
Complete cab, front clip and rolling chassis are already sold. Outside is great. The inside has some dents and dings. It should be a fairly easy fix. I could stick the tailgate on a Greyhound. It will probably cost $50. Are you sure you don't want to make a trip to Pensacola? It would probably cost you the same. Let me know.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Outside is great. The inside has some dents and dings. It should be a fairly easy fix. I could stick the tailgate on a Greyhound. It will probably cost $50. Are you sure you don't want to make a trip to Pensacola? It would probably cost you the same. Let me know.[/QUOTE]
Do you have any pics I plan on linexing the inside of my bed. Wish I had know I was just down there this past weekend
1986 GMC 4x4 |
#7 | |
Do you plan on coming back any time soon? I can hold it for you for a while if you pay for it. I'll take $250 for the gate and the radiator. LMK. R
Hart Rod,
Does the engine and tranny work? Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
![]() Join Date: May 2009
Do you have the big block engine stands. If so how much shipped to 67401. Thanks
I'll take $150 shipped for the stands AND the motor mounts.
Ok I will et you know Thanks
![]() Join Date: Jul 2009
what's the story on the BB 402 and tranny ? motor running and complete with intake and carb ? tranny needs ?
It's complete (factory carb and intake), both motor/tranny will need to be rebuilt.
I am always a day late and a dollar short. I do need a cab more than anything. And a right 68 fender and a right door. You know the drill.
Kerry
#15 |
Totally understand Kerry. I'll keep my eye out for a cab, door and fender...
#16 |
Hart
Thanks but i found one a little closer tuesday. I think im going to go with it good luck with your sell
1986 GMC 4x4 |
#17 |
Junior Member
What condition is the shroud? Are the tabs broken or any cracks?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#18 | |
No cracks and not broken. Here's some pictures:
#19 |
Tightwad
Has the towers and mounts been sold yet? What about the alt brackets?
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
#20 |
I still have them both.....
#21 |
Bed, tailgate and heat shield have been sold...everything else is still available.
#22 |
Prestige Worldwide
![]() Join Date: Feb 2001
Rob,
You entertaining offers on that engine and tranny?? ![]() J |
#23 |
Junior Member
I will take the fan shroud sending PM.
#24 |
What ya thinking J?
Shroud sold! Thanks R/
#25 |
all pulleys and brackets and ps set up sold .mike
