01-13-2003, 08:17 PM | #1 |
Location: Bondurant, IA but in Worcester, MA for school
What torque converter stall speed should I get??
I have a 350/350 with 4.10 rear end and wanted to upgrade to a higher stall converter to improve the launch of my truck...I was wondering what stall speed i should get? Thanks
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
01-13-2003, 08:38 PM | #2 |
Fabricate till you "puke"
What are the specs on your cam?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-13-2003, 08:41 PM | #3 |
its pritty close to stock i think.
HotROd
01-13-2003, 09:07 PM | #4 |
unless you are planning a larger cam down the road, you wont need too much extra stall. I would say something in the range of 2000-2200 should do you. Good luck.....crazyL
01-13-2003, 10:54 PM | #5 |
you want the stall to be around your max torque rpm..if you ahve astockish cam..max torque will be real low..1800-2200 and run out of rpm around 4000-4500..if put a 3000 stall, then you would only have a 1000-1500 rpm range to use..now if you had a cam with a rpm range of 2500-6000 rpm, and max torque at 3000, then a stall converter of atleast 3000 would be a good choice. Also the steeper gear and more torque the engine puts out the more stall you will get out of an advertised stall converter.
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
