![]() Join Date: Jan 2007
1968 C10 SWB Fleetside
I need to sell my project truck. I would love to finish this thing, but I have no room for it anymore. So here it goes. I have a ton of stuff for this project and I would like to keep it all together. The wheels are off of a 2000 Tahoe limited. The tires are 265/60R16 BFGoodrich Radial T/As. This truck has most of the body work done to it other than bondo. The front end is primered minus the doors. New body pieces include hood, complete one piece floor, front bed panel, rear bumper, radiator support, battery tray, and new inner fenders left & right. All of the rest is original pieces which in my opinion and in my experience are better than the aftermarket pieces. The bed is from Maryland and is not rusted at all, but has several dents across the top from what I can figure it was used as a work truck at one time. The tailgate is from arizona (i believe) and is completely rust free and straight. The cab has a one piece floor in it with new rockers, cab corners and etc. The roof was also rusted and has been replaced. The bottom inside and out of the passenger door has been replaced. The drivers door is rust free but has a small dent at the top and some of the mounting bolt holes are stripped. The drivetrain is a 305 V8 with a NV 3500 5 Speed manual transmission behind it. It also has a hydraulic clutch. It has power steering and it has been converted to power disc brakes (disc front drum rear). It has a 12 bolt rear end with 4:10 gears. It also has leaf springs in the rear with a sway bar along with 2 inch drop shackles and brand new bushings in the leafs. I have a brand new 4 core radiator, along with a V8 2WD fan shroud. It has new gas shocks front and rear. I have a floor shift non tilt column to go with the 5 speed on the floor. The fuel tank has been removed from the cab and the hole has been welded shut. And I have an aluminum tank that goes between the frame rails behind the rear end with the necessary stuff to install it and make it work. I have a bunch of stuff for the interior, but i do not have a seat cover, carpet, dash pad or arm rests. I have new door panels, door handles, glove box, and a whole bunch of other stuff I cant remember. I have a new weatherstrip kit and stainless door sill plates with the bow ties in the middle. I have brand new marker lights for the front (they are complete assemblies). I have the original front windshield and rear window. I have all the parts and pieces to put this back together. And probably a bunch more stuff. I would like to get $7,000 for all of this stuff. If you want I can transport this within a 100 mile radius of where I live which is Montgomery, PA 17752. Please ask any questions here that you might have. Thanks!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Redden05; 09-11-2009 at 08:12 PM. Reason: wrong tire size |
![]() Join Date: Apr 2005
Re: 1968 C10 SWB Fleetside
If you decide to part, I would be interested in the wheels.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
one set closer
If you decide to part, I would be interested in the rear sway bar.
upgrade Last edited by UP GRADE; 09-08-2009 at 09:35 PM. |
![]() Join Date: Jul 2009
im in on the bed
Restoration Virgin!
if you decide to part, I'd be interested in the fuel tank....
Good luck with the sell!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
What are those wheels off of??Those fit and look darn niceGM??
The wheels are off of a 2000 Tahoe Limited which were 2WD and 5 lug. And yes I thought they looked really nice too.
Here is a picture of the door panels:
![]() ![]() And I have a set of these mirrors (new): ![]() |
any interest?
If you did part, I'd be interested in the rims and tires and the mirrors and door panels/sill plates. Let me know.
Good luck with the sale. Tom
Bamafrost "Wars fought, uprisings quelled, Coup d'Etats planned...right after my nap". '68 Rambler American 2 door post Built 340/727/8.75 w 3.73 posi '68 C10 shortie soon to have a 2.5/4 drop and new Americans: 16" x 8" chrome IROC's |
Put me in line for the tailgate if you part it out.
Do you still have the mirrors?
I will not be parting this. If no one is interested in it, then I will just finish it... thanks.
The wheels off of this truck are for sale here:
http://67-72chevytrucks.com/vboard/s...45#post3717445 Although the truck is not for sale anymore. |
